JWT Popcharger need oiling?
Old May 30, 2005 | 09:48 PM
JP_WRX's Avatar
JP_WRX
Default JWT Popcharger need oiling?
This is probably a stupid question, but I've heard some people say something along the lines of 'reoiling the filter' in reference to the popcharger. Doe the filter require oiling before installation?
I couldn't totally disregard the possibility that this was the case because it is basically the same filter element as a K&N and I know those require oiling prior to install.
Any input would be appreciated as I will be installing this tomorrow. (Bought it slightly used, hence no instructions so I couldn't go off of that.)
Thanks
Old May 30, 2005 | 10:07 PM
Strife350z's Avatar
Strife350z
the popcharger comes pre-oiled, so normally, you don't need to oil it again before installation
but since you bought it used, I would check the filter to make sure it's not too dirty... if it is, then you may need to get a cleaner/re-oil kit for it
Old May 31, 2005 | 09:27 AM
black350's Avatar
black350
i would suggest this as well, besides, the whole cleaning process only takes about an hour. just make sure to read the instructions before you clean, and do not to OVER OIL, or else you can kiss your MAF good by.
Old May 31, 2005 | 12:41 PM
JP_WRX's Avatar
JP_WRX
Basically the same rules on cleaning/ applying oil as on a K&N I would guess? Not too difficult. For that matter, could you just USE the K&N cleaner/oil?
Old May 31, 2005 | 03:01 PM
black350's Avatar
black350
ive been.
Old Jun 1, 2005 | 05:49 AM
txsunset's Avatar
txsunset
I use the Holley Power Shot cleaning kit. The filter oil is blue like the Popcharger. K&N oil is red.
Old Jun 1, 2005 | 08:29 AM
DrVolkl's Avatar
DrVolkl
I bought a can of the blue spray on oil from Performance Nissan...I've re-oiled my filter twice now in the 10k miles or so I've had the car.... I think once a year or once every 6 months is fine.
Most people probably would let it go 3 years or something, but I like to keep it as new as possible.
Old Jun 1, 2005 | 08:48 AM
JP_WRX's Avatar
JP_WRX
My concern exactly. Thanks everybody. Installed it last night....sounds GREAT!
Old Jun 4, 2005 | 07:33 AM
brendone's Avatar
brendone
Where can I get a cleaning kit w/ blue oil? I've got the K&N w/ red oil for my wifes g35c, but I want to keep mine blue.
Old Jun 4, 2005 | 10:39 AM
txsunset's Avatar
txsunset
www.summitracing.com or check with local speed shops. I get my Holley PowerShot cleaning kit at Speedtek in Dallas.
Old Jun 4, 2005 | 12:52 PM
Jason@Performance's Avatar
Jason@Performance
Performance Nissan
The JWT Pop Charger comes pre-oiled. You do NOT need to re-oil before install...
The BLUE oil will fade to gray after a while even if it isnt dirty... Just because it is gray does NOT mean it needs to be re-oiled...
Only when you CLean the filter you will need to re-oil...
Jason
Old Jun 4, 2005 | 01:09 PM
southern_info's Avatar
southern_info
I would suggest after putting a good amount of miles on your JWT Popcharger is to get a air hose and blow all the debris and dirty off the filter as much as possible. Concentrating more from the inside of the popcharger blowing through filter.
lapham3
Oct 7, 2022 03:15 PM
apex locator
Jul 23, 2021 02:27 AM
