Crawford plenum install problem
Old Jun 24, 2005 | 09:33 PM
ZXiMan's Avatar
ZXiMan
Default Crawford plenum install problem
I inadvertantly disconnected the throttle-body harness when I removed the plenum and now the car won't even idle....
I was going to go to the big DFW G35/350Z meet in the morning but now it appears I am going nowhere!
Is there a fix for this or do I need to make plans to be stuck at home until the dealership opens monday morning...?????
I am so fustrated right now I could punch a hole in the wall...
I know it's late and I don't know if I'll get an answer tonight but if anyone has any ideas, please leave a reply here or send me a PM. Thanks
James
Old Jun 24, 2005 | 10:41 PM
ether's Avatar
ether
http://www.technosquareinc.com/350reset.htm
do the throttle valve reset and idle learn.. its a quick fix
Old Jun 24, 2005 | 10:45 PM
EdgeOfSanity's Avatar
EdgeOfSanity
sounds like an air leak
Old Jun 25, 2005 | 12:08 AM
ZXiMan's Avatar
ZXiMan
I tried the throttlebody relearn crap.... nothing changed.
I did hear some spit back sound coming from somewhere like a hiss. I wonder if that could be a leak or just the JWT Popcharger I installed at the same time
Old Jun 25, 2005 | 08:04 AM
EdgeOfSanity
air leak, if you want to find exactly where the leak is get a can of brake cleaner and spray it around the outside of the plenum. When the engine nearly stalls out that is where the leak is.
Old Jun 25, 2005 | 09:27 AM
bwilliams's Avatar
bwilliams
Another option to find air leaks:
get a tube about 2 feet long, about 1" diameter (ie, PVC so you don't short anything out). Put your ear on one end, move the other around the suspected areas. You'll hear mostly sounds from close to the tube opening. This is a trick I learned years ago to locate which valve lifter was slapping.
Old Jun 25, 2005 | 09:34 AM
StandAloneZ's Avatar
StandAloneZ
I ran into this problem too and found out that I didnt tighten the hex bolts on the throttle body enough. Once I tightened that up, my car idled normally.
Old Jun 25, 2005 | 10:29 AM
Nano's Avatar
Nano
sounds like an air leak. Even with harness disconected and without performing the whole idle learn and throtle close procedure, car should still somewhat idle.
Old Jun 27, 2005 | 07:11 AM
ZXiMan's Avatar
ZXiMan
I got it working thanks ;-)
Old Jun 27, 2005 | 07:56 AM
bio911's Avatar
bio911
what was the problem?
Old Jul 18, 2005 | 07:43 PM
ZXiMan's Avatar
ZXiMan
stupidity???
Uriyo_
Sep 8, 2021 08:46 AM
