Anybody tried these Car Chemistry Inserts?
I have the Xerd test pipes with a NISMO cat back, and they were just too loud at highway speeds (drone). Went to stock cats and the resulting loss in power and, because of the turbos, too quiet for me. The cost of hi flow cats is just plain crazy, I would rather spend the money on something else. I found these Car Chemistry Inserts that fit 2.5" pipe, 7" long, so they would fit in the lower part of the test pipes. Cost is around a $100 for two, and they come in two disk and three disk setups, with caps for further sound reduction if needed. A post on the company's website stated it removed drone. Has anybody used these? If so, did they remove rasp and drone? Thanks.
MOTORDYNE-MY350Z SPONSOR
They'll reduce the drone for sure but they will almost surely reduce power too.
You might want to try putting in an extra set of resonators. Get some magnaflow straight through mufflers for cheap. Put them in just about anywhere in the exhaust system and it will reduce the drone without killing your HP.
It would cost a little more and take a little more effort, but you would be happy with the results.
I did not have test pipes before the TT. Can't imagine how loud without TT. These are resonators that fit in the pipe instead of a seperate unit. You can buy these as a unit, and insert them into the exhuast system, or just put these in a section of straight pipe, and tack weld. They also make a set for use in header collectors. They claim minimal hp loss, or even some gain due to scavenger effect.
etkms
06-19-2022 06:30 PM
BobC-Z
09-18-2015 01:57 PM
Beater350z
09-09-2015 03:36 PM
