Cracked Cats
Old Jul 18, 2005 | 08:51 AM
space_audio's Avatar
space_audio
Default Cracked Cats
Hey Guys.
My Crawford Hi-flow cats (magna flow) have cracked near the weld that attaches to the OEM brace. The fracture is hair line and next to but not extending to the weld. Both are cracked in the same place. Anyone else with this problem?
The R bracket also broke where it attaches to the stock brace making the rattle I heard when starting the car.
The cost of repairs (welding, etc.) would be about the price of new test pipes. There is not too much in the forum on test pipes and an NA car. Any suggestions on how my set up will sound with the APS test pipes. My bet is it'll be too loud without a turbo especially at highway speeds.
Old Jul 18, 2005 | 12:41 PM
mrtomcat's Avatar
mrtomcat
have you contacted Crawford? He might be able to help you out
Old Jul 18, 2005 | 03:55 PM
lowrider's Avatar
lowrider
Any problem with a Crawford product - Call Doug at Crawford. Surprised you didn't call them first. No, I have never heard of this problem before.
Lou
Old Jul 18, 2005 | 05:08 PM
Z350Lover's Avatar
Z350Lover
Same happened to my cats.... 3 times already..... I would have called Doug if I was in the States.... it is way too far for me to reach him from australia...
cheers,
richie
Old Jul 18, 2005 | 05:22 PM
Nano's Avatar
Nano
mmm.. that brace is supposed to prevent the cats from cracking at the flange.
Is the brace attached to the heat shield or the pipes?
Old Jul 18, 2005 | 07:10 PM
Z350Lover's Avatar
Z350Lover
the brackets are attacted to the lower half of the cat itself, not the pipes... and the heat shield is located at the upper half of the cat.. not too sure if there is a heat shield at the lower half though... where I got the leak from (right at the joint of the brace and the cat)...
cheers,
richie
Old Jul 18, 2005 | 07:19 PM
zzzya's Avatar
zzzya
This is a common problem with test pipes/HF cats that have a brace on them to attach to the stock location when paired with aftermarket headers or exhausts. A lot of stress gets placed on those braces if there is not enough flex in the rest of the exhaust. I simply leave the brace off the car and have had zero problems. My Crawford HF cats don't even have the braces on them. Also, if your muffler shop is charging that much for a weld repair you need to shop around as I was charged $7 to fix a set of test pipes that I bought from someone on this site you neglected to tell me that the pipes I was purchasing had the same problem you are stating.
Old Jul 18, 2005 | 08:20 PM
Z350Lover's Avatar
Z350Lover
zzzya:
But if you take off the supports from those cats, wouldn't your headers actully stress from all the weight of the Y pipe + 2 heavy cats? If you have an after market headers (SS material), I guess those headers will get cracked easily though...
cheers,
richie
Old Jul 19, 2005 | 08:18 AM
space_audio
Thanks,
I'll call Doug but he can't help me much from Tennessee. Problem with the Z exhaust is that it basically hangs free supported mostly by the headers themselves.
I aggree that the fractures are due to heat stress/expansion in the different materials on the headers and cats. The joints needs more expansion. ? use a different gasket to allow for more expansion?
BTW - there are no heat shields involved. Also I aggree that removing the braces all together is a potential solution. Besides now I'm driving around with out support from the braces.
I'll shop arround for a better welding price. Maybe I can get away with not removing the cats and doing the welding from underneath the car. That way I save an hour of labor time needed to remove/replace the cats.
Any thoughts on APS test pipes and nismo exhaust.
Old Jul 19, 2005 | 09:26 AM
space_audio
Default doug to the rescue
Called Doug and he will send me a set of new reinforced cats. Apparently this problem is specific to some Z's with the Nismo exhaust. His solution is to add additional bracing. I'll let you guys know if it works.
Call or email Doug even if you live down under he is certainly a class act!
Old Jul 19, 2005 | 01:39 PM
FLFIRE's Avatar
FLFIRE
Now that is first class service!
Old Jul 19, 2005 | 04:13 PM
zzzya's Avatar
zzzya
Yeah he is not too fond of the Nismo exhaust But I can tell you that I have been running my car for nearly 2 years without that brace and have had zero problems.
Old Jul 19, 2005 | 04:27 PM
Z350Lover's Avatar
Z350Lover
space_audio:
Good to hear that mate.... I will give him an e-mail and see how it goes!
cheers,
richie
Old Jul 20, 2005 | 04:08 PM
Z350Lover's Avatar
Z350Lover
Update:
E-mailed Doug and he recognised this problem with nismo exhaust.... and guess what?! he is going to send another set down for me free of charge...... this is a serious first class service..... Thumbs up for Crawford, they do look after their customers no matter where you are!!!!
cheers,
richie
Old Jul 20, 2005 | 05:27 PM
FLFIRE's Avatar
FLFIRE
Originally Posted by Z350Lover
Update:
Has Doug stated what exhaust he recommends to go with the cats and headers?
Old Jul 20, 2005 | 06:21 PM
Z350Lover's Avatar
Z350Lover
no... he didn't do that... but he told me that he has already re-enforced the braces on all the new cats... and it will be good for those who are using nismo exhausts...
cheers,
richie
Old Jul 20, 2005 | 07:47 PM
lowrider's Avatar
lowrider
Doug runs a Borla on his "Baby II". I, on the other hand run an Invidia G200.
Lou
Old Jul 28, 2005 | 03:37 PM
Z350Lover's Avatar
Z350Lover
I installed the new cats last night.... got a large rattle noise.... and it happens to be the rattle from the cross member and the nismo mid pipe... (didn't that that before with the previous crawford cats though).. so I added a few washers in and it kinda solved that problem... but right now.. I am getting this kinda of rattling noise from the cat area (even at idle, and can hear more when I accelerate)... any idea???
cheers,
richie
Old Jul 28, 2005 | 11:13 PM
Z350Lover's Avatar
Z350Lover
Update again:
Rattle problem fixed... due to the heat shield... It goes very nicely now... Thanks Crawford!!!!
cheers,
richie
Old Jul 29, 2005 | 07:02 AM
3-fity's Avatar
3-fity
Thanks for the update! I currently have craford cats/borla and am getting the Nismo soon. Nice to know that Doug is so helpful and aware of the situation.
AbrasiveRaysive
Sep 20, 2021 02:29 PM
sales@czp
Sep 23, 2019 03:30 PM
Twenty4
Jan 17, 2016 01:20 PM
Li1ag
Sep 28, 2015 02:07 PM
