OEM CAI Hose Measurements
Old Aug 10, 2005 | 09:56 AM
sluggoZ's Avatar
sluggoZ
Default OEM CAI Hose Measurements
Does anyone have the measurements of the inside diameter of the OEM air tube hose? I'm trying to figure out what measurements I need for the hook-up of the Pi-thon air filter induction locks that connect to the JWT popcharger & for the air induction locks that connect on both ends of the OEM intake tube? Thanks. ps...do I need single ring air induction locks or double ring? What's the difference of the two?
Old Aug 10, 2005 | 06:31 PM
Major's Avatar
Major
These are approximate as I am using a tape measure.
I measured the inside diameter of the stock tube (the oem tube comes with the flexible connector already attached – part of the intake tube) is 3 inches inside diameter.
The ID diameter of the single ring air induction lock fully closed (compressed) is 3 5/16 or 3.3125 inches - the single ring air induction lock ID fully open is 3.5 inches and when the lock is fully closed the lock is 1 inch thick/wide.
Hope this helps I am thinking you need the single ring, but you might ask " Mapleleaf" at: http://www.zeetoyz.com/index1.htm to be sure!
Major
Old Aug 10, 2005 | 07:14 PM
sluggoZ's Avatar
sluggoZ
Major...Your the man! I appreciate it!
hulkout
Apr 28, 2017 09:00 PM
Z King
Vendor Wanted
13
Oct 22, 2015 11:39 AM
350z82
Oct 1, 2015 06:25 PM
