intake manifold help
Old Aug 25, 2005 | 03:04 PM
63zora's Avatar
63zora
Default intake manifold help
I'm looking at purchasing an intake manifold. My only engine mods so far are grounding kit and jwt popcharger. Searching through the posts, theres a lot of mixed reviews about the new SSV and everybody likes the crawford. Theres also the new 350evo coming out. I want to keep the Z na and very soon I plan on going aftermarket from headers-exhaust. What would you all recommend for top HP/torque increase? Also what are these manifold spacers all about? Thanks for the help.
Old Aug 28, 2005 | 09:50 PM
MY350Z.COM's Avatar
I dont know much about the SSV but I know that many people have had great experiences with the Crawford unit.
Spacers work by adding height to the stock plenum to add more volume.
Old Aug 29, 2005 | 10:56 AM
Landbarger's Avatar
Landbarger
At least wait until the 350EVO one comes out. For an NA car, doesn't look like there's going to be anything to beat it, at least not yet.
Old Aug 29, 2005 | 10:34 PM
ALL_MTR_GTS's Avatar
ALL_MTR_GTS
I have this same problem, I am going to wait to see what 350evo does. If the gains are worth the buck then im going that route if not crawford it is.
Old Aug 30, 2005 | 03:58 PM
MustGoFastR's Avatar
MustGoFastR
ETA on 350evo unit?
Old Aug 30, 2005 | 06:28 PM
RyanAtAltered's Avatar
RyanAtAltered
Altered Atmosphere makes a plenum angled spacer. Basically the idea behind the spacer is to get the maximum amount of air volume into the plenum without losing the factory strut bar (which if I recall correctly, some of our compentitors, do not allow you to keep) and keeping the factory appearance. It's a sleeper type of mod. We sell the spacer kit for 269.99 with everything you need (also this month we're offering a special where if you buy the spacer you get $50 off an ECU reflash). Gains in hp are similar to other plenums (obviously it'll all depend on the car and mods you currently have), and you get to keep your strut bar so your handling doesn't suffer.
Old Aug 31, 2005 | 05:37 PM
ALL_MTR_GTS
Originally Posted by MustGoFastR
ETA on 350evo unit?
i thought i read that it will be out right for christmas. but who knows
Old Sep 1, 2005 | 01:18 PM
zachcrosen's Avatar
zachcrosen
If it helps in your decision, here are pix of the Kinetix SSV on my Z!!! As far as I am concerned, it is the best looking performance/appearance mods for under the hood. I think it has shown gains awesome gains on a F/I car and average gains on a N/A car. If you ever plan on going F/I, you should consider this IM.
Attached Thumbnails intake manifold help-zachs-car-002-custom-.jpg   intake manifold help-zachs-car-003-custom-.jpg   intake manifold help-zachs-car-004-custom-.jpg
Old Sep 1, 2005 | 04:53 PM
undrgnd's Avatar
undrgnd
Is the SSV going to yield any gains on the 2005 300hp engine? Or is this something to ask the mfgr? I suspect his answer would always be "of-course".
Old Sep 1, 2005 | 04:59 PM
Rickdogg's Avatar
Rickdogg
Out of hiatus
I believe gains will be minimal if at all since the 2005 track model has a hp bump due to the revised lower plenum. To my understanding, the SSV replaces both the upper and lower plenum.
Old Sep 1, 2005 | 07:12 PM
zachcrosen's Avatar
zachcrosen
I would assume it will add something. As Rickdogg said, I would assume gains would possibly be a little less since the new redesigned lower plenum. I would ask Kinetix about that.
Old Sep 1, 2005 | 07:31 PM
HarvesterUT's Avatar
HarvesterUT
I purchased the Motordyne 1/4" spacer back when they had the first GB. i will say that for $150 it might one of the best things to do. I'd say the average gain is about 2-3 HP in the lower band and 4-6 in the upper. not bad for price and the install is not bad at all.
apex locator
Jul 23, 2021 02:27 AM
