K&N CAI made a better sound but.....
Old Sep 14, 2005 | 03:19 PM
pss350z's Avatar
pss350z
Default K&N CAI made a better sound but.....
I'm hoping somebody can help me out, here, I just installed a K&N Typhoon CAI on my 350Z and it makes the car sound much better but the car feels less torquey. Now when i stomp on the gas peddle it just makes noise, before it actually put you in the seat (somewhat). I also noticed the car seems to get warmer and fuel consumption is up. I checked to make sure everything is on right and it seems to be. Please help me out!
Old Sep 14, 2005 | 03:50 PM
cvt's Avatar
cvt
as far as the car being less torquey..maybe you are just used to the car? why don't you install your stock air box in to make sure it's the intake.
Old Sep 14, 2005 | 10:15 PM
mrZeee's Avatar
mrZeee
I think most CAI's drop torque a bit with the bit of HP they increase...I'll see if I notice a difference when I get my Nismo CAI installed
Old Sep 15, 2005 | 05:19 AM
Roggan's Avatar
Roggan
I noticed the exact same thing when installing a open cone filter on my car (similar setup to the POP charger), i especially noticed the difference after switching back to the stock one again...
But i think there is some gain in HP at high RPM's instead (which is where i like it the most), stock i am quite feed up with the engine at high rpm's, the sound at 4.5+rpm is more like a noise then a propper engine note and the vibrations just makes you want to shift early...
BUT when i had my cone filter on it was a completly different story, mostly because of the sound, i always wanted to pull above 4.5k rpm! Cant wait to get my Typhoon next week + my HKS Dual TI hopefully within the next year or two (has been on backorder since 1½+ months now)...
When i get my Typhoon i will run a G measurement test (with my G-techpro) to see if there are any gains/losses in acceleration (which is the only important factor)
/Roger
Old Sep 15, 2005 | 05:37 AM
I’m 90 percent certain that the Typhoon adds peak horsepower and peak torque. What may have happened is that the modification altered the torque curve. I don’t use the butt dyno, nor do I pay for dyno tests. My testing is done under real life conditions at the dragstrip, and I’m happy with the results.
Old Sep 15, 2005 | 06:32 AM
cvt's Avatar
cvt
that 13.6 with only the intake?
sq40's Avatar
sq40
Just put a 3.9 Gear in there and call it a day.
Old Sep 15, 2005 | 06:53 AM
Yes.
Old Sep 15, 2005 | 07:43 AM
cvt's Avatar
cvt
Originally Posted by davidv
Yes.
so what time were you pulling before the intake? i'm really curious because i'm close to getting a typhoon myself
Old Sep 15, 2005 | 08:12 AM
Old Sep 15, 2005 | 08:27 AM
cvt's Avatar
cvt
holy crap!!! you went from a 13.941 to a 13.68??!! awesome...i would think a lot of it had to do with practice but that is still a big jump.
Old Sep 15, 2005 | 10:51 AM
xziteme's Avatar
xziteme
Try resetting the ECU.
Old Sep 15, 2005 | 12:37 PM
dragonplayboy's Avatar
dragonplayboy
I have the typhoon, and noticed a similar thing, though not as bad, and my mileage is still great! try the ECU reset, if you can't find it go to technosquare.com and they have it there. It's a pain in the *** but it helps. I think my next mod will be an ECU upgrade!
Old Sep 15, 2005 | 02:59 PM
You got it. The 13.688 time slip is under ideal conditions: temperature, humidity, track preparation.
Obadabot
Jun 18, 2023 11:31 PM
Justin100
Nov 29, 2015 03:58 PM
Z King
Vendor Wanted
13
Oct 22, 2015 11:39 AM
samansharif
Sep 25, 2015 12:31 PM
