does anyone have the nismo intake??
Old Sep 18, 2005 | 09:31 AM
lilaznxboi08's Avatar
lilaznxboi08
Default does anyone have the nismo intake??
i recently installed my nismo intake and everything went fine, until like 2 days after my engine light came on, anyone get this too? does anyone know what i might have done wrong?
Old Sep 18, 2005 | 09:45 AM
The Mike's Avatar
The Mike
I'm not engine guru but from all the posts i've read on this already... It probably has to do with your MAF. Check that you installed it with no leaks anywhere and you didn't mess up the sensor or wiring. My nismo intake never gave me probs but I let the dealer install it with a package of exhaust/catbacks as well.
Old Sep 18, 2005 | 09:51 AM
When you did the installation, you disconnected the negative battery terminal right?
Old Sep 18, 2005 | 09:48 PM
lilaznxboi08
i dont think your suppose to disconnect anything..i just followed the instructions.
Old Sep 18, 2005 | 10:48 PM
cvt's Avatar
cvt
just reset your ecu...i have had intakes in my past cars and i always had to reset the ecu to tget the initial CEL out.
Old Sep 19, 2005 | 12:26 AM
Jason@Performance's Avatar
Jason@Performance
Performance Nissan
If you want to swing by we can check it out for you...
did you make sure your filter was still on?
Old Sep 19, 2005 | 11:49 PM
MarquisDeSam's Avatar
MarquisDeSam
I had the Nismo. It tends to throw off the SES. Just disconnect your negative terminal on battery for about 5 minutes and make sure all your clamps are on tight. You might also notice your idle jumping around a bit, or being lower than stock. When I had mine, my car would stall after start up. Reset ECU, and everything was savvy.
apex locator
Jul 23, 2021 02:27 AM
nanotech
Oct 2, 2015 05:02 AM
Sleeper_Z
Sep 30, 2015 10:25 AM
