Need help with HFC's.
Old Oct 30, 2005 | 05:28 PM
Nismo 350z's Avatar
Nismo 350z
Default Need help with HFC's.
Hey guys. I just installed my Crawford HFC's a couple weeks ago and I have been enjoying it ever since. But last week something weird happend. Whenever I put the car in reverse it makes a weird grinding noise on the passanger side. This only happens in reverse and when I hit the gas in reverse it sounds like sh*t .It sounds like a loose bracket or something... I dunno. I went to the dealer and they said it was my heat sheild rubbing against something. I got it fixed but now it only comes once in a while. Any ideas on what should I do? I was thinking of taking it back to them for another look. Any help would be greatly appreciated.
Old Oct 30, 2005 | 07:21 PM
frostyrock7c's Avatar
frostyrock7c
I went from Helix Test Pipes(no noise) to Kinetix HFC's and I got the sound, I had to beat in my heat shield a bit with a mallet...now, no grinding noise
Old Oct 30, 2005 | 09:47 PM
homiusang's Avatar
homiusang
I second that. I bought a set of new crawdford cats from a board member and the heat shield came beaten to make a lil more clearance.
Old Oct 31, 2005 | 09:09 AM
Nismo 350z's Avatar
Nismo 350z
Ok but did u guys get the noise when you were in reverse or normal driving? I know the headers move when you put the car in reverse so maybe thats the problem?? And does the grinding damage anything in the engine?
Old Nov 1, 2005 | 09:36 AM
Nismo 350z's Avatar
Nismo 350z
Old Nov 1, 2005 | 01:22 PM
Nismo 350z's Avatar
Nismo 350z
Hello?
Old Nov 1, 2005 | 03:49 PM
jreiter's Avatar
jreiter
It sounds like you're just getting more engine movement in reverse than in forward gears, so you're probably just contacting the heat shields in reverse. Do like people are saying and pound in the heat shields a little more where they are contacting.
Old Nov 1, 2005 | 06:49 PM
frostyrock7c
I had that occasionally, I installed a Stillen engine dampener and it stopped alot of the noise that beating the heat shield didn't take care of.
BTW, sorry I should've mentioned that I had the dampener to begin with
Old Nov 1, 2005 | 06:54 PM
DayBlueZ's Avatar
DayBlueZ
Same here.
Old Nov 2, 2005 | 09:50 AM
Nismo 350z's Avatar
Nismo 350z
Ok thanks alot guy. I got it fixed at the dealer and it stopped for now but I am thinking of getting the engine dampener as you guys suggest.
silverbullet_Z
NA Builds
24
Nov 14, 2015 02:52 AM
AutoStore350z
Mar 13, 2007 06:23 PM
m1james@bellsou
Nov 20, 2006 02:13 PM
dingobiatch
Jul 1, 2006 08:05 AM
350Z_LMS
Apr 12, 2006 05:44 AM
