Would I need a tune after I/H/E and plenum?
Old Nov 22, 2005 | 08:14 PM
GolfinZ's Avatar
GolfinZ
Default Would I need a tune after I/H/E and plenum?
Title says it all...would I need a tune after Nismo intake, headers, exhaust and then the Motordyne spacer?
Old Nov 22, 2005 | 09:32 PM
Z BOY's Avatar
Z BOY
maybe, if you become too lean.
Old Nov 22, 2005 | 09:41 PM
Jason@Performance's Avatar
Jason@Performance
Performance Nissan
As long as you didnt change your cats to test pipes or high flows, youll be fine...
Old Nov 22, 2005 | 10:20 PM
HoldThisForMe's Avatar
HoldThisForMe
ok what about Cone Filter up front/AAM spacer/Helix TPS/RSR Examg GTII
Old Nov 22, 2005 | 10:25 PM
Jason@Performance
Performance Nissan
Test Pipes / High Flow Cats, no matter what other mods, your going to be running a little lean...
Old Nov 22, 2005 | 10:42 PM
thawk408's Avatar
thawk408
I am still running rich.
Old Nov 22, 2005 | 11:57 PM
Jason@Performance
Performance Nissan
how do you determine that?
from black sut on your exhaust tips? or did you get an air flow taking from dyno?
Old Nov 23, 2005 | 04:18 AM
Alberto's Avatar
Alberto
Cranky FI Owner
Not all Z's Ive seen have run lean from HF cats or tp's. They run leaner, but not lean, you know we run rich from the factory so we have some room to improve. Only one way to find out and thats go get it dyno'd with A/F, then decide if its needed.
Old Nov 23, 2005 | 04:54 AM
Need more information please. Do you have a diagnostic chart showing air:fuel ratio? “Rich” means what: 13.7:1?
Old Nov 23, 2005 | 05:08 AM
Alberto's Avatar
Alberto
Cranky FI Owner
David, 13.7 A/F would be a tad lean for an NA application. It wouldnt post a risk of any damage, but a little lean, ideally you want 12.8:1-13.5:1 NA, my Z makes good power at 13:1, my other car makes good power at 13.5-14:1, every car is different. Rich would be going toward the other end of the spectrum 12.5>
Old Nov 23, 2005 | 06:48 AM
InsaneChink's Avatar
InsaneChink
im actually getting also the exact same mods except i have the JWT pop charger. But i thought you should get it at least get it flashed to make it all come together...?? especially when modifying headers...
Old Nov 23, 2005 | 06:59 AM
thawk408's Avatar
thawk408
When I dynoed I had the A/F hooked up with a Inovate tailpipe sniffer.
The A/F ratios are on the bottom of the graph. This is all according to the Blue line.
http://community.webshots.com/photo/...38370850lJWBTB
Old Nov 23, 2005 | 07:09 AM
350Zenophile's Avatar
350Zenophile
Is that across the board? Here is the AFR from my stock pull using a tailpipe sniffer...btw, are these horribly innaccurate compared to a wideband? Is WB what most dynos use?
Attached Thumbnails Would I need a tune after I/H/E and plenum?-020505_afr.gif
Old Nov 23, 2005 | 07:16 AM
Thumbs up
Old Nov 23, 2005 | 07:59 AM
Alberto's Avatar
Alberto
Cranky FI Owner
These are just as accurate imo as a wideband. Your mods have made you a little lean down low and mid range and you get richer as rpm's rise. I think you would be a good candidate for an ecu reflash or a piggy back tuned. I had over 15:1 lean A/F's before I even did the flash, but Im glad I did, all the mods really came together. Dyno's use widebands but they usually measure through the tail-pipe aka sniffer. Some places put the wideband right into an exhaust bung, but you usually see that more in high hp FI applications.
BTW-what kind of dyno was that?
Old Nov 23, 2005 | 10:29 AM
350Zenophile
That was a Mustang dyno...but I think you misunderstood my post. That was my stock (before) AFR. I don't have my "after" to post yet...I did the after pull, but the printer was broken.
Old Nov 23, 2005 | 11:37 AM
Alberto's Avatar
Alberto
Cranky FI Owner
Oh ic. I would question there 02 sensor then because I have never seen a stock Z that lean. I would go to a different dyno and double check things now.
Old Nov 23, 2005 | 12:52 PM
thawk408's Avatar
thawk408
What do you think of mine? Does it look normal?
Old Nov 23, 2005 | 04:28 PM
Alberto's Avatar
Alberto
Cranky FI Owner
Where is your A/F graph? I saw nothing but a bunch of pics and dyno's in your sig with no A/F....
Old Nov 23, 2005 | 04:35 PM
thawk408's Avatar
thawk408
Bottom of the graph is the A/F numbers. This is all according to the blue line.
