plenum spacer on 2006?
i assume the same plenum spacer's that you guys are using on 03-05 z's would work on 06, but my question is would i get the same hp #'s or not?
it looks like alot of you peeps have upgraded that on your rides, and it sounds like a good deal for the hp#'s.
I'm not the one who really should be answering this, but if I am not mistaken, I beleive that the 2006 is the same as the 2005 anniversary engine. Hence, if anybody from 2005 with the track or anniversary engine did the upgrade, then yes.
-LamaZ
-LamaZ
actually you will probably want to speak to Tony from Motordyne engineering on
these forums. the word i heard is that the plenum spacer does not have notable
gains on a the revup engine. Tony addressed this with a new mod for the revup
engine only. i can't speak on the AAM spacer, etc. but i would assume the same
would be true with those as well on the revup engine.
the 2006 all contain the revup engine if i remember correctly. so definitely check
before you plunk some $$ down on a spacer alone on your revup.
daytona...
check out this thread from a while back. drop down to post #10 where Tony
(Hydrazine on the forums) talks about the 1/2" plenum spacer on the revup.
https://my350z.com/forum/engine-and-drivetrain/146774-05-high-rev-motors-18whp-22-29wtq-a-thanks-to-tony-motordyne-engineering.html
i would pm Tony if you need more information on the mod he has for the revup
motor. Tony is a good guy and his products are top notch. i'm running the 5/16"
on my non-revup motor and the gains are there. so i have no doubt the new NA
mod for the revup that he has will produce results. Performance Nissan has the
new mod on sell here and it goes for $487...
http://performancenissanparts.com/ca...oducts_id=5988
you can also get it directly from Motordyne Engineering here...
http://www.motordyneengineering.com/350Z.asp
hope that helps.
hope that helps.
Originally Posted by 06daytona
wow the trq looks nice..... but dang 500$ for only a few ponies, thats hard to justify
It won't do much for dyno queens or max HP bragging rights but it will give you a faster Z.
