Took off my Injen intake last weekend and saw something I didn't like.
Old Oct 15, 2003 | 11:04 AM
  #41
jelledge's Avatar
jelledge
Default OBX Catch Can
I got the OBX catch can because ut was only $50 and is pretty nice quality. You can check it out at www.2kracing.com
Look under exterior accessories...
Old Oct 15, 2003 | 01:35 PM
  #42
mpowers's Avatar
mpowers
I thought under scca rules you are not allowed to modify the pcv system (at least in the stock class).
Old Oct 15, 2003 | 11:19 PM
  #43
SlamMan's Avatar
SlamMan
Default Re: Catch Can
This guy has the correct concept.
Originally posted by jelledge
I have the stock air intake and get oil into the intake as well. I am getting oil pooling in the intake mainfold also after AUTOX. I have not been able to determine whether it is coming from the PCV valve route or from "vent tube" located on the other rocker cover as per the FSM.
There is only one PCV valve as per the FSM which is on the passenger side rocker cover. The other rocker cover only has a vent tube that goes into the intake tubing right after the bellows section. If you are seeing oil from this connection then it is due to high RPM load conditions and you need a catch can on that connection. According to the FSM this vent tube normally allows fresh intake air to be drawn into the crankcase under normal load. But under high load the flow can reverse and crank case gases (liquids too I guess) can enter from the crankcase into the intake path. Check out the PCV system in the FSM.
I am intalling my catch can on the "vent tube" as it called (the one right after the bellows section on the intake) to start with and see what happens. If this doesn't totally fix the oil problem then we will need two catch cans or something like that.
Also, simply putting a vented filter setup on the PCV valve can be bad. Under normal conditions the PCV valve allows a slight vacuum to be pulled on the crankcase. However if you simply vent it to atmosphere you can cause a pressure build up in the crankcase. Not good.
Old Oct 16, 2003 | 05:23 AM
  #44
CarFanatic's Avatar
CarFanatic
That is exactly what BJ told me from 350evo. They had puddling of oil in the intake, thats why they added a catch can. I'm curious to know how much oil is coming in from the line on the passenger side.
Old Oct 16, 2003 | 09:11 PM
  #45
bellox's Avatar
bellox
Oops, I'm hooked up my catch can wrong, in line with the tube hose. Got to move it to the PCV valve hose!
Old Oct 17, 2003 | 06:16 PM
  #46
Import-Tooner's Avatar
Import-Tooner
Here is one on a civic. I also wondered where they would hook up on our z's. I kinda understand but I'm more of a visual person
CIVIC
Old Oct 17, 2003 | 06:43 PM
  #47
Ag Z's Avatar
Ag Z
If you are worried about the oil mist at high RPM's then buy a cheap gas filter that is transparent and put it in the PCV hose. Any mist will hit the filter and separate out and over time you will be able to see what is really coming out of the engine.
I think a cheap filter that cost less than $5 is better than some $50 plus catch can. I am sure you take it into a dealership for service they would look real hard at the can vice the new hose you just replaced to remove all signs of the filter.
Old Oct 17, 2003 | 08:30 PM
  #48
all_bark's Avatar
all_bark
lots of varying opinions and information.
does everyone agree that the oil that gets into the intake is BAD?
Old Oct 17, 2003 | 08:34 PM
  #49
cheeves's Avatar
cheeves
So which is it guys? Recieved my Greddy tank today. Looks like it might take some creative plumbing to get her hooked up. Seems the Injen hose (the one with the filter in it) is 17mm. Only place I found hose this size was on the Injen website. Probably could use 3/4 hose, but still only able to find heater hose in this size. Would really like to use silicon hose. Anybody have a lead on hose? Anybody used the Greddy tank? Where did ya mount it? About the only open space is the little area where the stock intake airbox used to mount.
Old Oct 17, 2003 | 09:58 PM
  #50
roark's Avatar
roark
CIVIC
Is it just me or is that catch can in the Honda mounted way too high? I would want the top of the can to sit lower than either the PCV valve or the intake nipple.
I'm not an expert with this particular part so I'm asking the question.
Old Oct 19, 2003 | 07:08 PM
  #51
moog's Avatar
moog
Doesn't matter what height the catch can sits at. If the can gets even remotely close to being full, you can just empty it out.
Old Oct 19, 2003 | 07:37 PM
  #52
3kgto's Avatar
3kgto
We have a really limited space under our hood to squeeze anything in. But managed to locate the greddy catch tank under my filter. We had a custom bracket made to hold it there. My filter heat shield was basically in contact with the tank, so I stuck an insulating sponge in between to prevent any rattle.
I opted for braided hoses for a more "showcar" look though it'll not be necessary as there is no high pressure involved.
Attached Thumbnails Took off my Injen intake last weekend and saw something I didn't like.-catchtank1.jpg
Old Oct 19, 2003 | 07:38 PM
  #53
3kgto's Avatar
3kgto
More pic
Attached Thumbnails Took off my Injen intake last weekend and saw something I didn't like.-catchtank2.jpg
Old Oct 19, 2003 | 07:39 PM
  #54
3kgto's Avatar
3kgto
last one
Attached Thumbnails Took off my Injen intake last weekend and saw something I didn't like.-catchtank3.jpg
Old Oct 19, 2003 | 07:57 PM
  #55
SandMan's Avatar
SandMan
I have the Injen system and am looking to buy the Cusco Oil Catch tank. They have two sizes, 9mm and 15mm, is there a specific size I need to get or it doesn't really matter.
Old Oct 20, 2003 | 07:12 AM
  #56
theZman's Avatar
theZman
3kgto - very nice install. where did you buy the braided hoses from?
Old Oct 20, 2003 | 05:14 PM
  #57
iLLestJrz's Avatar
iLLestJrz
You would probably need 15mm
Old Oct 20, 2003 | 06:18 PM
  #58
alex30327's Avatar
alex30327
19mm and 15mm are just the sizes of the hoses that come with it.
Old Oct 20, 2003 | 07:09 PM
  #59
3kgto's Avatar
3kgto
Thanks,
I got it from the tuning shop who supplied me with the catch tank. I used about 5 feet of it, which wasn't exactly necessary (can do with about less than 4 feet), but to route it the neatest possible way used up the extra.
MAsSIVrOOM
Oct 20, 2023 10:50 AM
Z King
Vendor Wanted
13
Oct 22, 2015 11:39 AM
