Best Piggy back ECU for NA and cost effectiveness.
Title says it...
I want to get a piggyback, but I don't really want to spend 1000 on a Utec. What would u guys suggest? I have read a ton of threads on this stuff but not getting a straight answer, not interested in a reflash. I know people will have differing opions but that is what im looking for opinions.
So here are my details..
So far I have...
test pipes
headers
Plenum spacer
pop charger
crank pulley
In the future...
TD exhaust
Havent installed any of the above yet, I figured I should have it all done at once, except for the exhaust, dont have the cash for that right now. Thank you for your help!!! I will dyno after install for everyone to see results.
So far I have...
test pipes
headers
Plenum spacer
pop charger
crank pulley
In the future...
TD exhaust
UTEC is your best bet... If you wan a real deal, and you have a unichip tuner near you, I would imagine that you can find some great deals on unichip piggybacks from APS kit owners who have switched to something else...
Originally Posted by DG350Z
If you get 0 gain from a piggy back system, is a UTEC really worth 1 grand?
Simple - because most of the piggybacks (SAFR, SAFC) do not have their own drivers for fuel or ignition...they scale the stock signals. On OBD2 cars, this results in inconsistent numbers at best, and you'll find yourself constantly figiting with it
A UTEC is not a piggyback, it is a parrelle engine mgmt system
Either a UTEC or a properly tuned Emanage would be a far better choice...though at the point you load up the Emanage with the bells and whistles it needs to be a worthwhile setup, you are in UTEC price territory. Overall, I personally the find the UTEC to be a far more competant (consistent) system, and easier to use as well. YMMV
I don't suggest using piggybacks at all on the car, but that's just me. Overall, I found them to not work well, and only allowed you to make very small corrections before the stock ecu reverted back to stock. The nie thing about the parrallel system are that as your level of mods changes, you are able to remap the car to suit, and datalog each change you do to see exactly what the car is seeing.
Originally Posted by thawk408
What happend?
Whatever though, the biotch runs real strong now and is a lot quicker over stock.
Been using this for the last 3 years and my wideband confirms the settings stick.
Originally Posted by Jime
The S-AFC works fine as long as you program it for Hi-Throttle 40% and then just program the Hi-Throttle. Anything less than 40% and the ECU will revert it back. Don't bother with the Lo-Throttle at all.
Originally Posted by MRC Motorsports
You must be lucky, all the customers we had come in with the Super AFC installed in a Z, has issues..Mostly due to faulty install and improper tune, but none the less issues..I do not feel the super AFC has the ability to consistantly tune the 350z.If you really did a datalog of you car over a course of several weeks in different weather conditions, Im sure you would find the Super AFC very inconsistant in its state of tune.
Agreed if you have different weather conditions etc you need to retune but that goes for any setup if you want it 100%. The a/f will change a little due to weather but thats why we use weather stations and ET prediction software at the track. If I didn't want the timing, raised limiter, 2 step etc I would stick with the S-AFC.
Speaking of consistency I finished 2nd in the Bracket Import class and 4th in the Summit Series against the V8's in street class, nothing requires better consistency than bracket racing.
