Injen Install....Dyno Results
Old Jan 10, 2003 | 06:23 PM
webcarconnection's Avatar
webcarconnection
Thumbs up Injen Install....Dyno Results
I install the Injen System and went to the Dyno and let me tell you I was impress.
The car Stock (K&N) put 246 HP 233TQ. With the Pre- Silencer remove went to 249 HP and 235.5 TQ. So my base #s are 249 & 235.5 I did 3 run and all 3 went the same 259 HP and 245 TQ in 5th gear. I guess the difference between the promo HP that Injen have is not the same (5hp & 6tq) because they test the car in 3rd not 5th.
Thanks to Shawn and Jeremy of StreetSports for getting me the System.
Old Jan 10, 2003 | 06:27 PM
webcarconnection
Originally posted by VQracer
Is your dyno graph spikey?
Nice numbers BTW.
I dont understand what your asking
Old Jan 10, 2003 | 06:41 PM
vicmar90's Avatar
vicmar90
Looks good to me. Maybe I will get it afterall.
How do you like the sound?
Old Jan 10, 2003 | 06:42 PM
webcarconnection
example of a spikey graph
https://my350z.com/forum/attachment....&postid=162962
Sorry!.... well is not that spikey but have some, but is corrected in case your wondering!
Old Jan 10, 2003 | 06:45 PM
webcarconnection
Sounds great! for me is the perfect sound, not to much noise inside the car.
Old Jan 10, 2003 | 06:49 PM
vicmar90's Avatar
vicmar90
Was it easy to install?
Do you have pictures? I'm sure it must look good on your car because it is red.
Victor
Old Jan 10, 2003 | 07:07 PM
webcarconnection
Victor
Is not to hard to install...is OK!
Hopefully I'm gonna take pics on saturday or sunday, I will post them, dont worry.
Old Jan 10, 2003 | 08:48 PM
ppw350Z's Avatar
ppw350Z
very impressive numbers, i may be getting rid of the old pop charger real soon. has anyone went from the pop charger to the injen if so is it a major difference in sound? in your opinion is the sound better or worse?
Old Jan 10, 2003 | 08:55 PM
Emax02's Avatar
Emax02
Damn 259 HP is VERY impressive for a NA VQ35! I realy need to get a better manifold on my car!
Old Jan 10, 2003 | 09:21 PM
ares's Avatar
ares
Veteran
just curious, but could you possibly dyno it again in about 1000 miles? I wonder if itll kill you again when the ECU resets to the new hardware.
Old Jan 11, 2003 | 05:28 AM
McDan's Avatar
McDan
Default Re: Injen Install....Dyno Results
You're quoting SAE adjusted numbers, right?
Old Jan 11, 2003 | 06:20 AM
webcarconnection
What do you mean Killing again? the ECU adjust in the past never produce bad #s. in mine personal expirience.
Old Jan 11, 2003 | 06:23 AM
webcarconnection
Default Re: Re: Injen Install....Dyno Results
I believe So, there are corrected, but not sure is SAE, what are you understand for SAE?
Old Jan 11, 2003 | 08:08 AM
ares's Avatar
ares
Veteran
sae changes the HP to a standard amount that can be compared to other runs and other people in different locations with different weather conditions. you will dyno higher with higher pressure(lower altitude) and colder temps.
anyway, its just a rumor that the ECU is changing the program to back down the HP when it notices something new. but it seems to take a little while for it to do it. hence why people that have done true exhaust, and even injen intakes have not gained much, if any hp.
Old Jan 11, 2003 | 08:22 AM
n3985's Avatar
n3985
So reset the ECU, then it can take full advantage of the mods.
Old Jan 11, 2003 | 08:52 AM
wadd3456's Avatar
wadd3456
Here is a pic of mine. Give your car a few days, the intake will work even better.
camera is scratched, i know!
Old Jan 11, 2003 | 09:39 AM
ares's Avatar
ares
Veteran
doesnt seem to work like that, all that does is speed up the process. the ECU will retune the engine with whatever it senses, if it senses more air flow, it will cut back on the fuel to keep hp even. if you go REALLY crazy it will default to safe mode and kill your power.
Old Jan 11, 2003 | 09:53 AM
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
Why would the engine cut back on fuel if it senses more air?!?!?!?! That would induce a LEAN condition. Doesn't make any sense at all. When a MAF senses more air flow, it in turn tells the ECU to give the car more fuel. Not the other way around.
Old Jan 11, 2003 | 10:32 AM
ares's Avatar
ares
Veteran
Im not sure what it does actually I shouldnt have said that. but whatever it does it keeps the engine from putting out hp, either that or a dual exhaust reduces hp. many mods have shown little or no hp, maybe its true that stock is perfect; otherwise something is affecting it.
Old Jan 11, 2003 | 10:47 AM
Inzane's Avatar
Inzane
I purchased and installed Injen's CAI on my 350 about three weeks ago. Although I haven't Dyno'd it yet, I'd say I was VERY impressed in the low end torque. (Just when you think you've found perfection....) Injen's instructions for installation however, is a little scary for the DIYer. I did not disassemble the front end as per the instructions. Instead, I went through the diffuser. You can do everything from on top and removing all the bolts except the rear line of the diffuser and then GENTLY working everything into place. EASY install for all us DIYers!!!
Best of all is the performance when complete. Injen sends their DYNO results on the shipping box
Good sound - a little more throaty. You also get their license plate frame to hang on the back...
All in all I'd say another premium product from Injen
