cleaning JWT pop charger
Old Jan 3, 2006 | 09:45 AM
TriX's Avatar
TriX
Default cleaning JWT pop charger
i did a search but i wasn't too satisfied with the post.
anyone could briefly give me an idea on what needs to be done to clean it?
i read that i need to buy oil. remove the pop charger spray the oil let it dry then reinstall. am i correct here?
now sure what oil works best.
Old Jan 3, 2006 | 09:58 AM
TheLastSpartan's Avatar
TheLastSpartan
JWT sells oil on their webite
here -> http://www.jimwolftechnology.com/customer_results.asp
cleaning instructions -> http://www.jimwolftechnology.com/wol...ANING-INST.PDF
hope this helps!
Matt (needs to clean his popcharger as well )
Old Jan 3, 2006 | 10:03 AM
PoWeRtRiP's Avatar
PoWeRtRiP
its easy, take off the filter, use soapy water and a soft bristled scrub brush to remove the dirt on it. rinse well in clean water. re-oil filter generously, then wrap in paper towels and fill inside with paper towels, let dry in sun for at least an hour or two and reinstall. be sure to make sure that the entire filter gets oiled well and that the oil is mostly dried with the towels.
if u put it on there and the oil gets on your maf most likely it will fry it so make sure its dry. just use k&n recharge kit, can be had at most auto stores for about 10$
Old Jan 3, 2006 | 12:00 PM
+1 on the soapy water. I stick the filter on the end of a leaf blower. Dries in a couple of minutes. I don’t have a special spray: just WD-40.
Old Jan 3, 2006 | 01:00 PM
TriX's Avatar
TriX
thank you folks. exactly what i was looking for.
Old Jan 3, 2006 | 01:34 PM
HyperSprite's Avatar
HyperSprite
Mad Scientist
After reading the above responses, powertrip had it close.
Let dry completely
re-oil filter
but not generously, it does not need to be wet and then lifted off by towels, it should be lightly sprayed and allowed to soak in and spread. If you saw them do it at the factory you would be surprised how far a little oil goes.
just WD-40.
filter oil is way more tacky than wd-40 and tacky is what you want. I would be surprised if there is any wd-40 left on the filter after a few hundred miles.
Really, following the link posted by TheLastSpartan is your best bet.
Chris
Old Jan 3, 2006 | 02:48 PM
Tony@Performance's Avatar
Tony@Performance
Vendor - Former Vendor
we also sell the oil on our site:
http://performancenissanparts.com/ca...ywords=pop+oil
always in stokc
Old Jan 3, 2006 | 03:15 PM
Vamos_Rafael's Avatar
Vamos_Rafael
WD-40 smells like crap
david that stuff is bad for ur health
Old Jan 3, 2006 | 04:24 PM
plumpzz's Avatar
plumpzz
yeah... don't make the mistake i did and put oil on wet filter, it won't spread well and it wont dry and stick to the fibers and itll get sucked into ur manifold. when i took my manifold off, there were blue droplets all over the place...explains the large amount of smoke coming out of my exhaust for a week :-o.
Old Jan 3, 2006 | 04:37 PM
Vamos_Rafael
lol!
kyin
Oct 15, 2015 05:54 AM
_bit
Oct 2, 2015 07:49 AM
