Installing Motordyne spacer without torque wrench?
Old Jan 20, 2006 | 10:31 AM
Daytona350Texas's Avatar
Daytona350Texas
Default Installing Motordyne spacer without torque wrench?
I received my spacer this morning and just got off work. I was wondering how hard it is to install without being able to torque down. On the paper using a wrench it says the hand can tighten to 90inch lbs of torque or equiv. and with rubber gloves and do about 110.
My concern is what happens if you tighten to tight? or not tight enough? or should i wait and have a mechanic do it with a torque wrench?
Old Jan 20, 2006 | 10:37 AM
sq40's Avatar
sq40
Dude.. They are like $25 at the autoparts store..Buy a wrench..
Old Jan 20, 2006 | 11:02 AM
ahwai519's Avatar
ahwai519
plenum bolts are easy to break... better do it with a torque wrench and make sure you got the in/lb not the ft/lb wrench...
Old Jan 20, 2006 | 11:12 AM
disturbed2483's Avatar
disturbed2483
you should be able to hand tighten them with no problem, snug is all that needed.
Old Jan 20, 2006 | 12:07 PM
mutock's Avatar
mutock
Perhaps some useful threads......
https://my350z.com/forum/showthread....e+bolts+plenum
https://my350z.com/forum/showthread....+spacer+torque
Old Jan 20, 2006 | 01:26 PM
Not tight enough - vacuum leak.
Too tight: Break the tightening bolts. Crack the upper plenum.
Old Jan 20, 2006 | 01:55 PM
thegr8one99's Avatar
thegr8one99
Is the vacuum leak noticable to where you could just tighten it if you hear it. Or do you not hear it, and causes damage. I'm in the same position, whether or not to go buy a torque wrench.
Old Jan 20, 2006 | 02:04 PM
BhashaZ's Avatar
BhashaZ
If all else fails, buy it, use it, return it. Just tell them "It did not meet my needs."
(the torque wrench, that is).
Old Jan 20, 2006 | 02:58 PM
Daytona350Texas
Ok well so far havnt needed one and am half way finished with process. Question though, im back at installing the lower plenum... the gasket i took off between upper and lower, do i reuse? The center seems like it would leak without that special gasket? that would also mean im laying gaskets, something just doesnt make sense? anyone please help asap
Old Jan 20, 2006 | 03:00 PM
Daytona350Texas
o and the instructions say without using torque wrench that a hand can do about 90 inch/lbs and hand with rubber gloves can do 110 approx... so i should be fine without one, im just stuck at this middle gasket dilema, the thermal gasket is already on, im talking about the middle gasket u get to
Old Jan 20, 2006 | 03:02 PM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
Seems to be a common problem. I did the same though installing mine. Just went to our local Ace Hardware and bought stronger bolts.
Old Jan 20, 2006 | 03:06 PM
Daytona350Texas
cmon people i need an answer faster then this, yes or no on the doubling up on the gaskets :P doesnt say in instruction, and pic shows without, but looks like there would be a leak in middle without that first gasket
Old Jan 20, 2006 | 03:10 PM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
I went to local auto parts store and bought the gasket sealant. I also ordered a second gasket from Nissan. So use the stock one below the spacer and use the 2nd one/ gasket sealant on top.
Does that help?
Old Jan 20, 2006 | 03:14 PM
Daytona350Texas
that makes sense, thanks
Old Jan 20, 2006 | 06:08 PM
thegr8one99
I just went to auto zone to get a torque wrench and the one they had we like 160-900inch (or something like that). The other ones were ft/lb. I told them what I needed and they were like don't waste your money on that. Just use your hands and slight turn with a wrench. ???
Old Jan 20, 2006 | 07:03 PM
showstoppertk's Avatar
showstoppertk
sorry, but I wouldn't trust the mechanical advice of the guys who work at autozone, checkers, etc anymore than my girlfriends taste in movies. sears should set a micrometer torque wrench that will be within the correct range. otherwise go online and shop around. I got one from these guys. it was cheap, it works well, and the customer service was excellent.
http://www.toolsource.com/ost/produc...zratemtn16200#
Old Jan 20, 2006 | 07:11 PM
steela2110's Avatar
steela2110
Installing this should be the easiest thing you will ever do!
Old Jan 20, 2006 | 08:06 PM
Sorry no one is paying attention. Two gaskets: one on each side of the spacer.
Old Jan 21, 2006 | 04:40 AM
plumpzz's Avatar
plumpzz
use ur hands. ur not he man, u wont break it dont worry. Tighten it, check for leaks. if its leaking, tighten more.. if not, ur fine.
And 2 gaskets..not 1...
Old Jan 21, 2006 | 06:56 AM
SOLO-350Z's Avatar
SOLO-350Z
'12 TL SH-AWD
Actually the INCH pound TQ wrench is required! Not a Foot LB. The foot lb are $25 bucks. You need one that goes BELOW 100 inch LB. And the only place that has one is Sears and they are $70-80 bucks. It is a must trust me.
All the auto part stores have a inch lb one, but they don't go below 100 lb setting. (cheap ones oh well)
This is what you need.
http://www.sears.com/sr/javasr/produ...orque+Wrenches
