Installed Megan Testpipes
Old Feb 17, 2006 | 06:29 PM
MR.OKKKK's Avatar
MR.OKKKK
Default Installed Megan Testpipes
i have a question.. right after i got my testpipes installed i was driving home. Everytime i release the gas pedal and step on my brakes theres a vibration?? like for 1 second and it goes away... or if i push the gas pedal it goes away.. Is this normal? because where i got it installed, the mechanic told me no leaks, etc, and everything is good..
Old Feb 17, 2006 | 06:33 PM
MR.OKKKK's Avatar
MR.OKKKK
my other mods are a popcharger... and i also got the vairs air duct installed....
Old Feb 17, 2006 | 06:36 PM
Vamos_Rafael's Avatar
Vamos_Rafael
re-tighten the bolts...
if its rattle then something is lose...
vibration?
well lifting off will cause stress in ur exhaust system...
maybe thats what you are feeling...
Old Feb 17, 2006 | 07:33 PM
MR.OKKKK's Avatar
MR.OKKKK
yea because it isnt rattles.. i guess it was just stress.. thank you.. and i my engine light go off... i heard that it does when you dont do the nonfoulers?
Old Feb 17, 2006 | 07:47 PM
Vamos_Rafael
reset the battery...
mine went off somehow after the dealer touched it then i reset the battery (leaving it off for a long *** time) cured it...
Old Feb 17, 2006 | 07:52 PM
Test pipes should not rattle: there is nothing inside the pipe. If you can get the car on a lift, check for clearance. Consider that engine torque moves the exhaust manifold and test pipes. So clearance can be deceptive. Also look at the OEM heat shields. Are they tight? Are they necessary?
Old Feb 17, 2006 | 07:53 PM
MR.OKKKK's Avatar
MR.OKKKK
roger that... ill be disconnecting my battery before i go to sleep.. hehe
Old Feb 17, 2006 | 07:56 PM
I forgot to mention that I appreciate you not mentioning rasp. Rasp (or whatever it is
) shows up in every test pipe thread like like its some sort of plague to be avoided at all costs. Rasp has gotten way too much attention.
Old Feb 17, 2006 | 08:08 PM
MR.OKKKK's Avatar
MR.OKKKK
and i have a rasping noise.. anyone know why?
kekeke... yeah i knew about the rasp... so i didnt want to bug you guys with it...
Old Feb 17, 2006 | 08:34 PM
FairLadeeeZ's Avatar
FairLadeeeZ
Why is rasp so terrible? I have a little w/ just my helix y-back, but me likes!
Old Feb 17, 2006 | 09:14 PM
plumpzz's Avatar
plumpzz
heh its not bad till you have a 3 inch duall exhaust with 3.5 inch test pipes on an NA car... the rasp is unavoidable and it really isn't too bad with even with my exhaust and test pipes
Old Feb 18, 2006 | 03:19 PM
MR.OKKKK's Avatar
MR.OKKKK
ok... i reseted the ecu.. i did the steps on technosquare... my car still has that problem.. its like a lil vibration that it goes away... i guess i have to wait till my car gets used to it? because the bodyshop told me nothings lose, etc.. everything is fine... oh wells... gotta wait and see..
Stevo Z
Oct 3, 2015 09:14 PM
