Header O2 Bung
For anyone who has ever done the non-fouler workaround for the test pipes, have you also performed the same workaround for the bung on the collector of the header? I just want to make sure there is enough room in that area as the non-fouler sticks out about 3 inches...
I know it's necessary to do this to prevent a CEL on >= '05 (for test pipes), just not sure if it's necessary/possible for the headers as I will also be installing headers at the same time.
Thanks!!!
Thanks!!!
There is no work around necessary for the oxygen sensor in the headers. OBDII compares the pre-catalytic converter air to the post-catalytic converter air. The objective of the test pipe non-fouler is to move the oxygen sensor out of the exhaust stream so that it reads clean.
Please correct me if I am wrong.
gothchick
16
Apr 22, 2018 01:18 AM
National Speed
Aug 22, 2012 06:39 AM
JDSMotoring
Jul 7, 2011 08:43 PM
