For those with Crawford HFC's...
Originally Posted by PieroG35
I got the same problem. My SES light recently turned on and it must be the cats.
Did anyone have fitment issues with the crawford catalytics and the heatshields under the car? My drivers side one is only a 1/4 of an inch away from the underbody heatshields and i think is making occasional contact.
my heatshield rattled against the HFC's upon install, all I did was that I used a metal bar to push the shield back like half an inch and it never rattled again.
-Andy
-Andy
I ended up pressing in the heatshield a bit, but it still was too close. I ended up having a friend grind away part of the crawford cat heatshield and so far im rattle free. Also had to put 4 washers on the V brace in the rear of the car, as the mid pipe was hitting. I must say though, now that i have no contact, the combo sounds incredible.
Originally Posted by mikead_99
I've been thinking of throwing some hfc's on mine, but it seems most that do that end up with cracks after a little while. Were your's the older style or the newer type with the reinforced bend?
+1 on that. I'm still holding out on cats or resonated test pipes because all I keep hearing about is cracks, leaks, rasp, rattle etc.
Why is it so hard for somebody to weld up quality pipes that don't crack?
can you be a little more descriptive about the rattling that you're hearing? I'm asking because i think i might be experiencing the same thing. Its not all the time and usually when the car is cold. its more like a buzz/rattle when i accelerate hard.
i think one of the reasons people like the crawfords is because they look stock and would pass a visual....for those who have to worry about it.
to solve the cracking, take it to a muffler shop and have them beef up the welds were the brackets are on the cats...about 40 bucks.
i have had mine now for a couple of years and i really like them....a great mod for performance. they also transition nicely with headers and cat backs since the same size diameter with regards to the inlet and outlet sizes on the cats
KONVERTER
Aug 18, 2003 10:40 AM
