MREV+ Dyno Tested On The 287 HP Engine!
MOTORDYNE-MY350Z SPONSOR
Originally Posted by kpiskin
Also I'm wondering if it changed the sound of the engine....
Originally Posted by Hydrazine
And nobody has reported a torque loss with a MREV+ on a non-revup because they have never been sold to non-revup customers. As of today, this is the first and only MREV+ to be installed on a non-revup engine.
Also, (to date) there has never once been a dyno showing a loss of torque or HP with a plenum spacer. Scientific dyno test or otherwise.
Sorry, I can't make it on Saturday.
My wife reminded me of prior obligations.
holy cow! great work... so how will the core exchange work? Core gets shipped to you first before an MMP'd core gets shipped back?
for everyone else: just to clarify what motordyne is saying... if you have a non-revup and you want the MMP mod on your lower plenum WITHOUT exchanging your core, you need to purchase the MREV and the MREV+ upgrade. That basically gives you a SECOND lower plenum that's been MMP'd.
Just thought I'd clarify since I sensed confusion in the earlier posts (or maybe it was just me
Originally Posted by amG35
Tony will this work with and add anything to an engine that already has a Crawford V5 plenum? On an '05 G35 5AT, if it is a factor. Thanks.
This MMP increases flow area in a way that a spacer or plenum cant.
Originally Posted by Strife350z
hmm btw looking at the dynos more carefully... why did the baselines read so high (260?) for a stock '04 G35 sedan?
The car was also tuned prior to the baseline testing. The baseline was with a stock plenum setup.
Nothing about the car was changed during the four test sequences except for the plenum mods.
)Or you could send in your lower plenum and wait for it to be modified...
Or you could recieve somebodyelses modified lower plenum immediatly and send in your stock lower plenum for a core redund when you are done.
So there are a few different ways it can be done.
Dynapack dyno numbers primarily.
I know that you've dealt with this forum with 100% integrity...... but there are vendors that have faked dyno charts by purposefully showing the baseline on a rich tune... so i hope you don't mind the skeptism
Cool... but by tuned prior, do you mean it was reflashed/piggy backed?
good point; i'd be curious what it looks like on a stock (untuned) ECU
Originally Posted by vantage350z
so the MREV Plus lower plenum is $122, how much of a refund do we get back when we send you our stock lower plenum?
And I understand the skepticism. There are so many manufacturers that claim bogus or wildly exaggerated HP gains that any experienced mod installer would know better.
As with any of the other Motordyne products, independant testing is encouraged. I am confident these gains will be independantly repeatable.
It was tuned to a nominal 12.75-13.0 A/F with a Greddy EU. The car even in its relatively stock condition was running very lean at WOT in the 14-15 A/F range. Way too lean for good health or good testing. So the tune was not to turn it into a dyno queen. More than anything it was to bring A/F back into a nominal range.
So the machining appears to be a small flat spot milled on the top of the two forwardmost intake runners. Is that all that is required to free up the breathing of the plenum? Seems so simple so easy! Why, I bet it wouldn't take 30 minutes to do the whole job. I bet I could do it myself down in my basement shop on the mill. Hydrazine, do you mind my asking how much you take off?
Do you guys have your own dyno?
The thing about this post that itches my brain is that you have done these tests on a G35 sedan. Well, the G has a different intake and exhaust from a Z, now doesn't it?
I would love to see some dyno results on a Z. In fact, I have an all-stock-motor Z with the 287hp motor, and I would love to confirm these results by installing these products on my Z. I don't expect to see the same gains on the Z as on the G, but if the results are good, I'll be more than happy to pay for the mods.
Any chance I could bring my car down to your place and we could hook something up?
Note: As an engineer and a researcher, I realize that companies like yours are subject to a lot of scrutiny and skepticism. When I am producing results in *my* lab, I know I have to do a FULL AND COMPLETE set of experiments just so that the paper I am trying to publish doesn't fall under the scrutiny of this type:
"Great results on X, now why didn't you test Y and Z?"
Something of this nature actually happened to our research group recently, and while it hurts to have people think you might be omitting bad results to make your main results look better, it is ultimately something that you just need to do.
I believe you are obligated, for your own good, to complete a dyno test on a Z. For the sake of repeatable results, and for the sake of completing an unambiguous set of experiments that everyone can agree are (1) Unskewed and (2) repeatable on ANY 287HP VQ35, not just one with the G35 sedan setup.
