MREV+ Dyno Tested On The 287 HP Engine!
Old Apr 1, 2006 | 04:56 PM
  #41
Hydrazine's Avatar
Hydrazine
MOTORDYNE-MY350Z SPONSOR
Originally Posted by Wired 24/7
Do you guys have your own dyno?
The thing about this post that itches my brain is that you have done these tests on a G35 sedan. Well, the G has a different intake and exhaust from a Z, now doesn't it?
I would love to see some dyno results on a Z. In fact, I have an all-stock-motor Z with the 287hp motor, and I would love to confirm these results by installing these products on my Z. I don't expect to see the same gains on the Z as on the G, but if the results are good, I'll be more than happy to pay for the mods.
Any chance I could bring my car down to your place and we could hook something up?
Note: As an engineer and a researcher, I realize that companies like yours are subject to a lot of scrutiny and skepticism. When I am producing results in *my* lab, I know I have to do a FULL AND COMPLETE set of experiments just so that the paper I am trying to publish doesn't fall under the scrutiny of this type:
"Great results on X, now why didn't you test Y and Z?"
Something of this nature actually happened to our research group recently, and while it hurts to have people think you might be omitting bad results to make your main results look better, it is ultimately something that you just need to do.
I believe you are obligated, for your own good, to complete a dyno test on a Z. For the sake of repeatable results, and for the sake of completing an unambiguous set of experiments that everyone can agree are (1) Unskewed and (2) repeatable on ANY 287HP VQ35, not just one with the G35 sedan setup.
I agree.
We don't own a dyno (yet ) but your proposal is good.
Skepticism is normal and expected with the release of any new product.
And this is why I test the products very carefully before releasing any information on it.
Motordyne can exchange a MMP lower plenum (no charge) if you can dyno it and publish the results here.
Use the dyno shop of your choice. I can do the installation on the dyno if you are somewhat local. If you would like to test the entire sequence I can supply a spacer, hardware and any tools needed for the testing.
Which ever you prefer.
One thing that I ask for is:
Same dyno
Same day
Same ambient conditions
Same tank of gas
ECU resets at the beginning of each set
Same coolant temperature (190'F +/- 2 degF)
All mod installations performed without removing the car from the dyno.
And all other variables be held as constant as reasonably possible.
Tony
Old Apr 2, 2006 | 12:04 AM
  #42
Todd-350Z's Avatar
Todd-350Z
Tony,
Just to clarify - for a 287 motor/stock intake - in order to add this entire "package" we would need to order:
1. 5/16" Spacer $235
2. MREV Plus $122
3. Core Charge for stock lower $222
Total $579
Stock lower collector returned for credit (core charge) $222
Final cost at the end of the project = $357
Add shipping to receive MREV parts.
Add shipping to return stock lower collector for core charge credit.
Is this correct?
Or would the entire MREV setup have to be purchased?
1. Iso Thermal MREV $487 [comes with 5/16" spacer]
2. MREV Plus $122
Total: $831
Final cost at the end of the project = $609
Plus shipping charges as stated above.
Thanks for your time and research.
Old Apr 2, 2006 | 01:59 AM
  #43
Z BOY's Avatar
Z BOY
group buy? also, how much was a/f affected?
Old Apr 2, 2006 | 10:54 AM
  #44
OCG35Coupe's Avatar
OCG35Coupe
Originally Posted by Hydrazine
The refundable core charge is $222.
So its $344 to buy the modified 287 lower plenum.
Then we get back $222 when we send in our stock lower plenum?
So total is $344-222= $122
Is that correct?
Old Apr 2, 2006 | 10:57 AM
  #45
HarvesterUT's Avatar
HarvesterUT
Is that correct?
i think so, yes
Old Apr 2, 2006 | 10:58 AM
  #46
OCG35Coupe's Avatar
OCG35Coupe
Originally Posted by HarvesterUT
i think so, yes
Sweet! Im all over it.
Old Apr 2, 2006 | 11:32 AM
  #47
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
Same dyno
Same day
Same tank of gas
Tony
I wouldn't have it any other way either.
Let me figure out what shop has a dyno nearby and I'll try to make some arrangements.
-Mike
Old Apr 2, 2006 | 09:58 PM
  #48
3hree5ive0ero's Avatar
3hree5ive0ero
Retired Admin
subscribing
Old Apr 2, 2006 | 10:17 PM
  #49
3hree5ive0ero
Retired Admin
wait.. i'm confused..
Tony, can you clarify what we would have to buy? I have an 03 Z..
all i would have to get is:
- 5/16" Iso Thermal Plenum Spacer ($265)
- MREV plus ($344)
- if we send in our factory lower plenum (-$222)
total of $387 + shipping for the most gain still using our factory strut bar on an 03 Z correct?
Old Apr 3, 2006 | 12:31 AM
  #50
100122923's Avatar
100122923
subscribing
Old Apr 3, 2006 | 06:55 AM
  #51
Hydrazine's Avatar
Hydrazine
Hey guys,
Seeing how the maching process was able to make gains by modifying one area if the lower plenum, I was thinking I may be able to do the same machining process to another area of the lower plenum. I think I see an area that could benefit fom it.
I've dyno tested a lot of different modifications to the lower plenum and I know some types of modifications don't work and some work well. The latests results are shown above.
Knowing what works, I had an idea on how it may be possible to apply this to a another area of the lower plenum. I should be able to machine this additional modification to the lower plenum this week and dyno it on the same G35 sedan. I'll post the results and we'll see what it does to the power curve.
Wired 24/7 - If it makes additional gains (on top of the gains shown above) you can pre/post test it on your Z.
Tony
Old Apr 3, 2006 | 07:00 AM
  #52
Jime's Avatar
Jime
Tony how is the MREV going to work with a 1/2" spacer? Any thoughts? I am asking since I already have the 1/2".
  #53
HarvesterUT
can't wait to see the results!
Old Apr 3, 2006 | 07:08 AM
  #54
Hydrazine's Avatar
Hydrazine
I think it will.
Probably similar to the pre/post numbers shown with the spacer already installed.
Old Apr 3, 2006 | 07:17 AM
  #55
Hydrazine's Avatar
Hydrazine
Sorry, can't do GB's now that we have distributors.
Good question about the A/F. Especially considering you have the HKS SC.
....YES It shifted A/F up ~2/10th's of a point. Not much, but we did see it.
Old Apr 3, 2006 | 11:14 AM
  #56
Jun's Avatar
Jun
subscribing.
Old Apr 3, 2006 | 01:55 PM
  #57
laswyguy's Avatar
laswyguy
Sub
Old Apr 3, 2006 | 02:44 PM
  #58
HyperSprite's Avatar
HyperSprite
Mad Scientist
Old Apr 3, 2006 | 06:49 PM
  #59
ct350z's Avatar
ct350z
subscribed
Old Apr 3, 2006 | 08:31 PM
  #60
Z BOY's Avatar
Z BOY
thanx, tony. i'm considering buying your new machined plenum mod, but first i have to find out how much the piggy back that comes with the hks sc can richen things up. i'll let you know.
