MREV+ Dyno Tested On The 287 HP Engine!
Old Apr 3, 2006 | 11:46 PM
  #61
Z BOY's Avatar
Z BOY
Originally Posted by Hydrazine
Hey guys,
Seeing how the maching process was able to make gains by modifying one area if the lower plenum, I was thinking I may be able to do the same machining process to another area of the lower plenum. I think I see an area that could benefit fom it.
I've dyno tested a lot of different modifications to the lower plenum and I know some types of modifications don't work and some work well. The latests results are shown above.
Knowing what works, I had an idea on how it may be possible to apply this to a another area of the lower plenum. I should be able to machine this additional modification to the lower plenum this week and dyno it on the same G35 sedan. I'll post the results and we'll see what it does to the power curve.
Wired 24/7 - If it makes additional gains (on top of the gains shown above) you can pre/post test it on your Z.
Tony
are you going to put the sale of your present machined-plenum mod on hold until you finish machining and testing the other area?
Old Apr 4, 2006 | 03:15 AM
  #62
Z350Lover's Avatar
Z350Lover
sub...
good work tony!
cheers,
richie
Old Apr 4, 2006 | 05:57 AM
  #63
trescincuenta's Avatar
trescincuenta
Subscribed woot woot!
Old Apr 4, 2006 | 06:14 AM
  #64
Zincognito's Avatar
Zincognito
Very ******* interesting, where do i sign??
G
Old Apr 4, 2006 | 06:53 AM
  #65
Hydrazine's Avatar
Hydrazine
MOTORDYNE-MY350Z SPONSOR
Yes. It wont be long though. It'll be worth the wait to see what the additional change will do.
Old Apr 4, 2006 | 06:54 AM
  #66
Hydrazine's Avatar
Hydrazine
Originally Posted by G35 6MT
Does that mean my newly placed order will include this mod or just the last mod that machined the runners for cylinders 1 & 2?
I have a 2003 G35 coupe 6MT, in case your interested
If it hasn't shipped already, we can put a hold on your order untill after the additional testing (if you prefer).
Give me a PM with your invoice number and let me know what you would like to do.
Tony
Old Apr 6, 2006 | 06:44 AM
  #67
infidsg35's Avatar
infidsg35
Hey I already have the Crawford upper plenum installed. How will you Lower Plenum work with this? +/- Gains?
Thanx
Old Apr 6, 2006 | 09:15 AM
  #68
vantage350z's Avatar
vantage350z
I also have crawford and would like to see if its worth getting the lower plenum and the iso gasket.
Old Apr 6, 2006 | 09:23 AM
  #69
RNL323's Avatar
RNL323
Mod My Ride
subscribing!
Old Apr 6, 2006 | 12:41 PM
  #70
Hydrazine's Avatar
Hydrazine
Additional modification to the lower plenum has been made! It took a lot of material removal for this one. We'll see what it does on the dyno.
Old Apr 6, 2006 | 12:44 PM
  #71
Hydrazine's Avatar
Hydrazine
Thanx
Would you like to install one on the Dyno?
Dont change anything but install the new modified lower plenum.
Same dyno, same day, no unstrapping and all that stuff.
Old Apr 6, 2006 | 01:40 PM
  #72
trescincuenta
Woohoo I cant wait to see the results!!!
Old Apr 6, 2006 | 02:09 PM
  #73
amG35's Avatar
amG35
Tony, does removing the material weaken the lower plenum or will the removal cause fatigue of the lower plenum over time? Thanks.
Old Apr 6, 2006 | 02:31 PM
  #74
HockeyZ39's Avatar
HockeyZ39
subscribed!
Old Apr 6, 2006 | 05:46 PM
  #75
Hydrazine's Avatar
Hydrazine
Nope. Not in the least.
Old Apr 6, 2006 | 07:51 PM
  #76
3hree5ive0ero's Avatar
3hree5ive0ero
Retired Admin
waiting for the results!
Old Apr 7, 2006 | 08:12 AM
  #77
MustGoFastR's Avatar
MustGoFastR
Very interesting, indeed. When you hitting the Dyno?
I would also like to see what it does with a Crawford plenum, as opposed to the spacer (though I have a Kinetix v4 plenum; should be about the same).
Old Apr 7, 2006 | 09:42 AM
  #78
99atlantic's Avatar
99atlantic
i wana see results with a 1/2'' spacer ^_^
Old Apr 7, 2006 | 02:15 PM
  #79
BigZ88's Avatar
BigZ88
subscribed
Old Apr 7, 2006 | 02:19 PM
  #80
EyeCbatty's Avatar
EyeCbatty
subscribed
