MREV+ Dyno Tested On The 287 HP Engine!
Old Apr 11, 2006 | 06:22 PM
  #101
BigZ88's Avatar
BigZ88
Looks good! how do you drive the ecu into "performance mode" thats the first i've heard of that.
i hope you keep extracting power!
wish i ddint live so far so i could get hooked up and get in some dyno time!
Old Apr 11, 2006 | 06:30 PM
  #102
baron's Avatar
baron
Tony,
Thanks for the results. Do you know if the addition of an intake (CAI or short ram) would add any more gains to the mod of lower plenum + spacer?
Thanks,
Baron
Old Apr 11, 2006 | 07:36 PM
  #103
Hydrazine's Avatar
Hydrazine
MOTORDYNE-MY350Z SPONSOR
Originally Posted by Z BOY
tony, when will you have the newest version of the machined lower plenums ready for sale, and do you anticipate any further lower plenum modification and testing in the near future, or have you maxed it out?
ps: how can more air=lower a/f?
I'll get the website setup for it soon.
And as of now, I can't see anything left to do as far as lower plenum mods are concerned. Port and polish is the only thing left to do but it doesn't really do much.
And good question about more air=lower A/F.... I don't know how it does that. I only know I have seen it more than once, and I have only seen this on plenum mods. Never on exhaust mods.
Old Apr 11, 2006 | 07:51 PM
  #104
Hydrazine's Avatar
Hydrazine
Resets.
Sometimes the ECU will go into granny mode and pull back on timing. Sometimes a reset makes a big difference and sometimes it makes no difference at all.
Old Apr 11, 2006 | 10:45 PM
  #105
Nismo 350z's Avatar
Nismo 350z
So are you saying you made more power on the 287hp non rev-up engine by adding this MREV++?? Is that what this is. I thought the MREV was only for Rev-up motors. Looks like you gained 6hp and 3ft/lb. with just the modified lower plenum. How much would a 5/16th spacer add?
Old Apr 11, 2006 | 11:05 PM
  #106
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
We shall see, we shall see.
Old Apr 11, 2006 | 11:56 PM
  #107
3hree5ive0ero's Avatar
3hree5ive0ero
Retired Admin
i'm kinda confused.. but hopefully somebody will clear things up as far as what i need to buy to get the most performance gain..
i'm guessing 5/16 iso-thermal plenum spacer & MREV+(remachined for 287hp engines)?
waiting for the dyno results and the website to update..
i'm itchin to get this for my car!! hurry up!!
Old Apr 12, 2006 | 01:28 AM
  #108
amG35's Avatar
amG35
What is the cause of the erratic plot at 5200 RPM? Thanks.
Old Apr 12, 2006 | 05:43 AM
  #109
Hydrazine's Avatar
Hydrazine
Yes and yes. The regular MREV is only for the revup motors. Installing a MREV on a 287 engine would be no differerent than installing just a spacer because the lower collector is identical.
But it turns out that the lower collector modifications being performed on the lower collector of the MREV+ or even the MREV++ is also good for more HP on the 287 engine.
I know it may be confusing but hang in there. I will consolidate the product line to simplify it.
EDIT:
6HP in the midrange from the last modification seems like a lot. I certaintly hope it works that good but I would also like to see it repeated on another vehicle. If it is shown to be repeatable then its party time!
Lets get it dynod once again on WIRED 24/7's Z to validate the results.
Old Apr 12, 2006 | 05:51 AM
  #110
Hydrazine's Avatar
Hydrazine
I asked the dyno operator the same question... He didn't know. It was a momentary loss of telemetry at some point. I've seen this happen on both Mustang dynos and Dynojets. ...I don't know why. The dyno machine was clean and in new condition.
Old Apr 12, 2006 | 06:54 AM
  #111
GeoFX's Avatar
GeoFX
EDIT:
Tony, can't wait to try your MREV++ kit with the 5/16" spacer on my FX35 on Friday. Will be doing before and after 0-60 GTech runs as well.
Old Apr 12, 2006 | 08:16 AM
  #112
LMG_35C's Avatar
LMG_35C
Tony
- Many thanks for the dyno runs w/AF ratio. That's what I was asking about earlier - this is kinda wierd behavior for intake improvements isn't it? But I'll take whatever it seems to get.
Can you just confirm what year/model and other mods, if any, were involved in this last dyno? I've kinda lost track of all this.
Looks like my waiting to place an order is getting close to over.
THANKS
Old Apr 12, 2006 | 08:39 AM
  #113
MustGoFastR's Avatar
MustGoFastR
I'll be helping with the install. We'll be sure to take lots of pics (without giving away any of Tony's secrets ) and post impressions.
Old Apr 12, 2006 | 09:08 AM
  #114
kpiskin's Avatar
kpiskin
It seems like the first MREV mod (MREV+) actually made more power than the MREV++, am I wrong?
Old Apr 12, 2006 | 09:37 AM
  #115
MustGoFastR
dyno above shows MREV++ had gains over MREV+. 1st pull (blue line) was MREV+, second pull (red line) was MREV++.
Old Apr 12, 2006 | 11:10 AM
  #116
dovla's Avatar
dovla
Tony, this mod for additional gains is just great. Thanks
Did I read this right: MREV+ increased AF 20% of 1 R and MREV++ decreased these 20% of 1 R plus it decreased another 5% of 1 R?
If so, this is good news for us with leaner AFR, and if MREV++ with 1/2" spacer will perform on dyno as expected then this is mod I definitely like to have.
Absolutely nothing was changed between the pre/post dyno runs except for installing the new lower plenum. The car was not removed from the dyno and the ECU was purposfully driven into performance mode before each set.
What is interesting to see in the plot above is that the new modification shifted A/F down about a 1/4 point through most of the curve. This isn't the first time I've seen a mod make power and simultaneously make it run a little richer, but it is always interesting to see.
Sorry, can't do GB's now that we have distributors.
Good question about the A/F. Especially considering you have the HKS SC.
....YES It shifted A/F up ~2/10th's of a point. Not much, but we did see it.
It was tuned to a nominal 12.75-13.0 A/F with a Greddy EU. The car even in its relatively stock condition was running very lean at WOT in the 14-15 A/F range. Way too lean for good health or good testing. So the tune was not to turn it into a dyno queen. More than anything it was to bring A/F back into a nominal range.
And I understand the skepticism. There are so many manufacturers that claim bogus or wildly exaggerated HP gains that any experienced mod installer would know better.
As with any of the other Motordyne products, independant testing is encouraged. I am confident these gains will be independantly repeatable.
Old Apr 12, 2006 | 11:21 AM
  #117
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
Originally Posted by G35 6MT
What are the dyno testing combinations your going to be testing this weekend for the plenum spacers?
I'm hoping the new and improved machined MREV++ 287HP lower plenum with a 5/16" spacer and a 1/2 spacer comparison.
Well, at the minimum I want to test:
-Baseline (my motor, intake, exhaust are all bone stock)
-MREV++ new collector
-Add 5/16" spacer
-If we have time, then hopefully do 1 more combo such as older MREV+ collector + 5/16" spacer
I don't see a need to test spacer by itself, because there have been quite a few independant dynos of the spacer IIRC.
Frankly I don't think we're going to be using the 1/2" spacer. The 5/16" is just so much more practical.
Old Apr 12, 2006 | 12:37 PM
  #118
Hydrazine's Avatar
Hydrazine
2004.5 G35 Sedan with a Greddy exhaust and EU.
I would say its prety close to stock condition. The Greddy exhaust was used so I could weld in a O2 sensor bung after the stock y pipe. I wouldn't say the Greddy exhaust is anything special. The resonators in the mid pipe are only 2" diameter flow through. This doesn't make it much better than the stock exhaust.
The EU certaintly helped because when the car was stock it was running 14.5 to 15.2 A/F WOT from ~3K RPM to Redline. Way too lean for safe operation on the track. So the EU was used primarily to fix an unsafe lean condition.
All in all, I would say it represents a relatively stock conditon for a G35 sedan.
Old Apr 12, 2006 | 04:04 PM
  #119
3hree5ive0ero
Retired Admin
-Add 5/16" spacer
i can't wait to see your results.. that's exactly what i wanted to know.. hopefully it's sometime soon cuz i've been waiting to get the spacer and now i find this, more waiting.. but oh well.. might as well wait a little longer for more hp to the z
Old Apr 12, 2006 | 04:19 PM
  #120
Hydrazine's Avatar
Hydrazine
We're all good to go.
I'll let Mike (Wired 24/7) set the appointment time to fit his schedule.
From what I know so far, it can be this weekend, Monday or next weekend.
