Cryo Cooler
Old Apr 5, 2006 | 08:15 AM
RBALDINELLII's Avatar
RBALDINELLII
Default Cryo Cooler
Has anyone thought about, or is using, this item. Its a cryo cooler that goes into the intake. Any thoughts or suggestions, besides using the search function, would be appreciated.
http://www.cryo2.com/products.asp?m=sp&pid=4
Old Apr 5, 2006 | 08:23 AM
HarvesterUT's Avatar
HarvesterUT
um..well...i suppose if it *could* reduce air temp by another 50 deg before hitting the cylinders then i guess it would be beneficial....dunno if it would actually do anything IRL
but at least it's a better idea than the turbonator
Old Apr 5, 2006 | 08:30 AM
Vamos_Rafael's Avatar
Vamos_Rafael
sounds too good to be true...
imo if u want to reduce intake temp, u should do the heat wrap for the tubing...
Old Apr 5, 2006 | 08:43 AM
zachcrosen's Avatar
zachcrosen
Correct me if I am wrong, but isnt this the same basic principal as using water/meth injection? Isnt the purpose to cool the intake charge to prevent detonation on boosted cars?
Old Apr 5, 2006 | 08:54 AM
Well lets see. Running at 5,000 rpm, a 3.5 liter engine ingests about 8,750 liters of air/minute (2,500 intake strokes x 3.5). Someone check my numbers.
Is this or any cooler capable of cooling 8,750 liters of air/minute? Think about it.
Old Apr 5, 2006 | 03:28 PM
97supratt's Avatar
97supratt
Its too much of a hassle for a few ponies, just run nitrous if you want to have a bottle in your car. If you have problems with detonation you can also try aqua mist water injection kits.
Old Apr 7, 2006 | 09:34 PM
R2theP's Avatar
R2theP
when I had my supercharged xterra alot of guys on the forums had really good results with this because of the lack of an intercooler on the motor, heat soak was a huge issue on the xterras and frontiers so much so, that people running smaller supercharger pulleys would get detonation in hot weather causing the computer to dump all the boost. As far as on a Z I doubt it would hurt but probably wouldnt be all that beneficial for daily driving, might help on drag racing times though. cooler air = denser air charge = more power. I kind of wonder if too much Co2 would kill power since youre basically putting a gas that is used in fire extinguishers into an internal combustion engine.
Just swap out the Co2 bottle for a nitrous bottle LOL!
Old Apr 7, 2006 | 10:22 PM
dscheers's Avatar
dscheers
I've got it on my car. Only for drag racing, biggest bottle last 6-8 runs.
Totally bogged down the engine on the dyno (intake sucking up CO2).
Car ran 0.7 secs slower on drag strip (again intake sucking up CO2).
Next step, enclosing the air filter and using a Varis airduct to feed it air from outside...
CO2 is way cheaper than N2O. And if the air intake sucks in N2O, you might get detonation (or more HP, but it's inearly mpossible to tune I guess...)
Danny
Old Apr 8, 2006 | 04:09 AM
Vq.turbo.DremZ's Avatar
Vq.turbo.DremZ
Danny
How was it being sucked into the intake? I understood it as that no Co2 was never deisgned to be injected into the motor itself, but rather fill a small bulb in the intake piping. Then, routed either to atmosphere or into something like they're fuel bar...
edit: I saw your sig. I assume that you have the intercooler sprayer and the excess Co2 is being sucked in by your supercharger, correct?
Old Apr 8, 2006 | 05:17 AM
jcarp's Avatar
jcarp
What if you use this with nitrous.
Old Apr 8, 2006 | 12:29 PM
dscheers's Avatar
dscheers
Correct. Especially on the dyno with the car standing still the effect is huge. On the drag strip, The effect is less but still noticable in ET.
Danny
Old Apr 8, 2006 | 12:30 PM
dscheers's Avatar
dscheers
If the air intake sucks in N2O, you might get detonation (or more HP, but it's nearly mpossible to tune I guess...)
Danny
apex locator
Jul 23, 2021 02:27 AM
seagrasser
Oct 11, 2015 03:27 PM
Rowlett
Misc.
Oct 2, 2015 10:38 AM
