idling problems after CAI install
Old Feb 3, 2003 | 12:13 AM
XBS's Avatar
XBS
Veteran
Default idling problems after CAI install
iv had my Injen CAI installed for a while now and it still idles low with the AC off it goes from 350-500 at idle i tried reseting the ECU has anyone had this problem can anyone tell me what there manual Z idles at with AC off?
Old Feb 3, 2003 | 09:01 AM
Chebosto's Avatar
Chebosto
be sure all your hoses are hooked up correctly and that there are no leaks from your MAF adapter.. check to see if the oring seal is there.
Old Feb 3, 2003 | 12:25 PM
XBS's Avatar
XBS
Veteran
what seal?
Old Feb 5, 2003 | 10:06 AM
XBS's Avatar
XBS
Veteran
can anyone help me out with this is there a seal that goes where the 4 screws on the MAFS are
Old Feb 5, 2003 | 03:12 PM
Ohio350z's Avatar
Ohio350z
Most of the intake mods don't do anything according to an interview with a nissan engineer that was posted a while ago. Your ECU is going into safe mode because it detects an error in the flow. My understanding is that the Z ECU needs to be remapped inorder to get any gains out of the intakes. I have not seen any dyno results that show any mathematically significant increase in HP at the rear wheels. Many of the DYNO results I have seen show a decrease with an intake put on because the ECU goes into safe mode.
Old Feb 5, 2003 | 04:20 PM
themyst's Avatar
themyst
I noticed a slightly lower idle, but nothing drastically noticable.
Old Feb 6, 2003 | 05:54 AM
Zaphod 350z's Avatar
Zaphod 350z
Hey bro, sorry I didn't get to finish our IM convo. I'm at work and I had to step away from my desk.
Anyway, I do believe that your problem lies in the PCV hose either popping off or not being completely on. I had to manipulate the hose quite a bit to get a satisfactory fit. If you want to be sure it's on and sealed, run a bead of silicone around it.
As far as the NOS, hit me up on IM and I'll tell you about it.
Old Feb 6, 2003 | 07:21 AM
Chebosto's Avatar
Chebosto
That's not true.
ECUs learn what you have on the car. it does not need to be recoded.
as far as "safe" modes go on Nissan ECUs. if anything bad happens. it wont let you rev over 3k and you will know if its in safe mode.
bad idle is a sign of air being vented somewhere its not supposed to.
check your throttle body hose connection. make sure its on tight.
as far as the seal goes, sorry. i might be mistaken. but normally, there is an oring on MAF sensors... sorry to trip you if the Z does not. maximas do.
Old Feb 6, 2003 | 11:52 PM
XBS's Avatar
XBS
Veteran
cool thanks does anyone know if there is a seal for sure thought.. i might have lost mine during install since a friend helped me install it
Old Feb 7, 2003 | 06:58 AM
Chebosto's Avatar
Chebosto
I looked up the MAF installation
this should help
there IS an O-ring like i suspected. its hard to see if you dont know its there.
the picture is worth a thousand words:
Old Feb 7, 2003 | 01:09 PM
jelledge's Avatar
jelledge
Default Idle Re-learning process also
If you find no vacuum leaks in your system as suggested above then you might need to run the "idle air volume learning" from the service manual.
The service manual has a explanation of how to do this. If you don't have the service manual I can email you the section required for this procedure. I can also provide a backup copy of the entire manual for a handling fee :-)
Email me privately at jelledge@micron.com if you need info on this procedure.
Jason
Old Feb 7, 2003 | 02:50 PM
Chebosto's Avatar
Chebosto
Default Re: Idle Re-learning process also
Dude. just give him a copy.
what the point of charging it? CDrs are like pennies now.
Uriyo_
Sep 8, 2021 08:46 AM
TDPrank
Sep 28, 2015 06:29 AM
