Best Race/Test Pipes for Nismo Exhaust
basically i have the nismo cai and exhaust and since south carolina has absolutely no form of emissions testing, i think i want to go ahead and remove my cats. what i'd like to know is what race/test pipe will sound best (and fit of course) with my current set up.
thanks,
james
thanks,
james
Guest
Posts: n/a
I had thought of buying test pipes, but since so many ppl were reporting cracked TP's, I bought a set of used OE cats and gutted them...perfect fitment and retains all mounting points - only downside is that they're still heavier than TP's.
Sound the best? Umm they are just a empty piece of pipe. The differences that you find are
Resonated vs non resonated
Hangers vs no hangers
Stay away from eBay junk and you will be fine.
A tube is a tube. A resonated tube is quieter / "less raspy" than a non-resonated tube. Some tubes are built with higher quality than others. In the end, it is just a tube and they should ahve similar performance.
If you understand this, you'll be fine.
I had Helix test pipes (non resonated) and I hated the rasp. I got some ebay ones (resonated) now and they sound great. Compared them to a buddies that spent 3x as much and they look the same, sound the same. The only thing that doesnt look the same is our wallets.
Just recieved a set of resonated test pipes and put them on with my Nismo cat back. They sound great I absolutely love them, but they rasp at wot and it annoys me to no end. Anyone have a solution to this which still allows me to keep the test pipes?
Originally Posted by whitebwoy
Doesn't a check engine light come on without having a cat? If you take out the cat on the stock pipe wouldnt that trigger a check light?
Yes it causes a CEL usually, but there are ways around it
Justin100
Nov 29, 2015 03:58 PM
