Headers? Worth it or not?
Old Apr 28, 2006 | 03:38 PM
NiSmO21z's Avatar
NiSmO21z
Question Headers? Worth it or not?
I've heard many things about them. What do you guys think? Worth it or not? Also, which ones if you do recommend it?
Old Apr 28, 2006 | 04:33 PM
nashjam's Avatar
nashjam
for the cost of install versus the potential gains...I would say...not
Old Apr 28, 2006 | 05:28 PM
Cannysage's Avatar
Cannysage
it's not all that worth it, but it doesn't matter.. you'll end up getting it anyways, soon or later, just to feed your addiction.
Old Apr 28, 2006 | 05:55 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
Personally I'm trying to leave open ended the possibility of going F/I, in which case headers are most likely not a great idea. That said, I'm not getting any mods that can't (or should not) be used with F/I until I have decided one way or the other.
Luckily the MREV++ V2 collector and 5/16" plenum spacer CAN be used with F/I... which is why I'm willing to get them (thanks Hydrazine).
If you know for certain, 100% that you're staying N/A, then I agree you'll probably do it eventually.
However, if I knew for certain, 100%, that I was staying N/A, my first mod would be a 3.9 final drive gear...
Old Apr 28, 2006 | 07:37 PM
99atlantic's Avatar
99atlantic
I love mine. Costs a lot to do it, but the power boost and the sound (Oooooo, the sound ) makes it definately worth it
Old Apr 29, 2006 | 04:43 AM
Roggan's Avatar
Roggan
I can tell you week after next when i get my Strups installed
I think if you can get a good price on the headers themselves and especially on installation (or have a super patiance and midget hands) its surely worth it from what ive heard and seen.
Most say that they feel a noticable increase in performance, and do dyno 5-15 extra ponnies depending on other mods.
/Roger
Old Apr 29, 2006 | 04:57 AM
techcontrol's Avatar
techcontrol
If you are staying N/A then headers are worth it. It took 7 hours to install them with the car on jackstands.
Old Apr 29, 2006 | 05:45 AM
Speedracer's Avatar
Speedracer
Headers will give you more power gain than any other bolt-on NA mod, but in terms of bang-for-buck, it is not a good value. Is it worth it? That's an individual decision. Figure on $2k for good headers, thermal coating and installation. You could install yourself and save a bundle, but the install is a B1TCH!
Old Apr 29, 2006 | 06:14 AM
Race against me tomorrow and decide for yourself if headers are worth the expense and headache:
https://my350z.com/forum/north-east/187113-350z-racing-in-md-sunday-april-30-a.html
Old Apr 29, 2006 | 07:35 AM
Beeker's Avatar
Beeker
I felt the biggest gains from headers. I gained power everywhere in the power band. Especially in the mid range. Like everyone else has said, if your staying NA then they are worth it.
Especially if you don't plan on changing out your stock cats. I am staying with stock cats because of all the threads I've read about running lean, rasp, cracking pipes, rattles, CEL's, etc, from hi flow cats and test pipes.
Installation isn't rocket science it is just very time consuming and annoying to do. Lots of scrapped knuckles and swearing. Keep in mind you can get a set of Strup headers for @500.00 and a set of gaskets for @50.00. So if you install them yourself it is a very good "bang for the buck" NA mod.
Old Apr 29, 2006 | 08:05 AM
Bubble's Avatar
Bubble
-REPLICA ARMY-
Yes. STRUP is my choice.
Old Apr 29, 2006 | 09:16 AM
99atlantic's Avatar
99atlantic
no leanness, rasp, cracks, rattles, SES, etc... from my high flow cats ^_^
The majority of cracks are usually associated w/ aftermarket y's or older models
The rattles are generally from models that needed 'modification' in order to fit
SESs are generally from test pipes
leanness is generally fomr test pipes
rasp is generally when it's been paired w/ certain aftermarket setups
All of it can be explained. HFCs have the least drawbacks.
Old Apr 29, 2006 | 09:24 AM
blackend's Avatar
blackend
if you go the turbo side then no need but if you go to SC then yes
Old Apr 29, 2006 | 09:40 AM
Beeker's Avatar
Beeker
Your right. I've heard there are far fewer problems with hi flows compared to test pipes. But I have read many posts about problems with hi flows as well. Cats failing internally, cracks, exhaust too loud, etc... I may still get a set one day but I want to hear them on a similar setup as mine before I get them. Plus, I will do a before and after dyno to make sure I'm not running too lean with them.
Old Apr 29, 2006 | 09:54 AM
hypeiv's Avatar
hypeiv
If you can do the install yourself I bet they are worth it... most of the shops around here want $400-500+ to install them in the Z b/c its such a PITA
Old Apr 29, 2006 | 10:07 AM
Bubble's Avatar
Bubble
-REPLICA ARMY-
with STRUP, around 4 hours.
Old Apr 29, 2006 | 10:18 AM
99atlantic's Avatar
99atlantic
exhaust too loud....pffft, that's a benefit
Old Apr 29, 2006 | 07:25 PM
hbenet's Avatar
hbenet
Just got my Nismo headers installed this week.... worth every penny.
Old May 1, 2006 | 08:22 PM
ISMSOLUTIONS's Avatar
ISMSOLUTIONS
Love my DCSports, Fast Intentions Resonated Test pipes and exhaust - man the sound is unbelievable!
Well - the Stillen CAI and MD 1/2" MREV ++ didn't hurt the sound either!
And the 3.92 GEARS!!! The car is a monster!!! Then again...cams and heads didn't hurt either
NA all the way....
Rick
oopss...G35 coupe
Old May 1, 2006 | 08:25 PM
adamb258's Avatar
adamb258
how much are the FI tp's?
