MREV 2 or 5/16th spacer + TS reflash... please help
Hey guys. I have a little dilemma here. Right now on my car I have a rev-up lower plenum on my 287hp non rev up Z. The car pulls great on the top end but low end tq is gone as you can see from my #'s. So I was thinking of swapping it out for a spacer or a MREV2. For those of you that have either a 5/16th spacer or a MREV2 with a TS reflash, how does the car pull above 6k? Also I haven't dynoed since I got my reflash, do you guys think I should go do it agian and see how much the reflash gave me? Which one would give mre power, a spacer or the MREV2? Hydrazine please help
MREV2 will produce more area under the curve.
The spacer will produce a higher peak power.
But even then, they both perform very similarly. Both predominantly add peak power.
If you have already done a reflash, you will be good to go with either or both!
I spoke with Andy from Perf. and he said that the rev-up lower collector is more for top end where as the spacer and mrev2 add more under the curve. Also wouldnt adding the spacer to the mrev2 only give like 3hp or something like that?
I have MRev2 on a non rev up motor and i can say no low end power was lost. I also just ordered from Hydrazine the isothermal 5/16 spacer and even though the performance gains may be minimal, its cooling properties could improve help overall. What do you think Tony?
I know the MREV adds low end power. I am asking about top-end power. Since I have a TS reflash, I can rev to 7100 and the rev-up lower plenum is said to make power all the way till 7500.
If you reved at 7500+ then I would suggest going with the REVUP collector but this will be a pretty rare example.
At 7100 and lower, the MREV2 clearly gives a higher average HP and area under the curve. Dyno plots show it has a tuning frequency better optimized for area under the curve.
So just the MREV2 or the MREV with a 5/16th spacer?
Install one or the other mod to start. Get a dyno and check your A/F. If you are in the 13's or lower you can add the other mod. If your are in the 14's don't add more mods unless you get a reflash or engine management.
Tony
Originally Posted by Hydrazine
It depends on where your A/F is starting at. Some cars come rich from the factory and some come lean. I've seen stock cars with A/F's as low as 11's and as high as 14's.
Tony
Tony
I already have a reflash and my AFR is set at 13.3 across the rpm range.
Please post your delta results with HP and AF if you get it dynod.
Tony
Hi Tony, what do you recommend for my setup? Currently I have popcharger and TS ECU reflash on my 06 revup motor. I'm considering going with the 5/16th spacer and MREV combo. Except I wanted to know what you recommended the MREV+ or MREV2. Here's my last dyno chart with my setup as it is right now.
could you also interpret my AF graph for me? I'm not quite sure what it means.
thanks in advance,
Dan
BTW, my redline is at 7500
thanks in advance,
Dan
Originally Posted by Blue_Z
i just read this and I wanted to make sure everything's clear... I have a redline of 7500 after TS Reflash. Do you suggest I stay with the revup collector then? Any idea what would happen when I tried to rev to 7500 using the MREV2? Or did you really mean 7500+ as in a redline of 8000 which is very rare.
To really know, it would be best to have actual electronic dyno data so I could export it into Excel. Once its in excel I could do a rigorous analysis to see which did best.
Despite being close, there is also the variable of how you drive. If you rev high all the time, maybe. If you drive mostly on the street, absolutely.
It would be close.
FromGtoZ
Sep 20, 2015 03:41 PM
