MREV2 5/16 spacer on 287 w/ tune
Old Jul 16, 2006 | 01:44 PM
masterj26's Avatar
masterj26
Default MREV2 5/16 spacer on 287 w/ tune
I am waiting the arrival of my Q unichip and already have the MREV 2 installed on my 287 motor, has any body actually got a tune after the install of both MREV 2 and 5/16 spacer? Here is the dyno from Wired 24/7 car:
Originally Posted by Wired 24/7
Here are the dynos.
Note that I do not have the dynos comparing the baseline to the MREV V2 by itself ... YET! These dynos are compareing baseline to MREV V2 + 5/16" spacer.
I forgot to get those printouts when I was there... it was getting late (4 hours after the place already was supposed to close) and we had been installing MREVs for about 7 hours straight.
I will get my hands on those graphs. The files are there, I just need to get them from Church's.
I will let the dynos speak for themselves, except a couple of notes:
notice how the very best baseline still does not compare to even the very worst modded dyno. Bottom line is, this is a kick-*** mod for the money. Guaranteed horsepower and you can really feel it
Edit: THE AIR/FUEL READS 1.0 POINTS TOO LEAN! The motor is NOT at 15 AFR, it hits a peak of 14 AFR.
Edit: More notes:
  • All dyno runs were done on 91 octane. (California's finest)
  • All runs were done on the same tank of gas and at the same engine coolant temperature.
  • Mods were installed without removing the car from the dyno.
More Dynos to come!! Don't forget to subscribe / stay tuned!
-Mike
P.S. The title where it says "Matt R 350z HKS SC" is incorrect, I already got a PM about that The computer has some kind of glitch with creating titles of the charts. Even though my dyno was done first, Matt (Z BOY's) dyno was PRINTED first. Just ignore the title...
Here is where he said that you probably would benefit from a tune with the mrev2 and spacer combined
Guys, you can look at the dyno charts more than one way.
On one hand, the MREV2 produced a higher peak HP and higher peak TQ number. But only slightly.
On the other hand, adding the 5/16" spacer beats the MREV2 in the top end.
It has a flatter HP peak and makes better HP up to the rev limiter.
Bottom line is:
MREV2 is the best bang for your buck.
MREV2 + 5/16" spacer is also very good and can benefit more than just the MREV2 if you get a tune
That is my take on it.
You cannot just say "OMG the 5/16" spacer lost power and that's that." That is true in one sense, but false in another.
****Disclaimer: I am not being urged by Tony to say these things in any way. This is MY take on the situation and if the 5/16" spacer sucked ***, I would gladly say so. ****
since i am gonna have the tune done just trying to see if it is worth it to have the spacer installed to? I don't want to spend the 260 if i am going to see no difference.
Old Jul 16, 2006 | 03:21 PM
Nismo 350z's Avatar
Nismo 350z
Thats exactly what I was wondering.
Old Jul 16, 2006 | 08:10 PM
Zincognito's Avatar
Zincognito
Old Jul 16, 2006 | 10:29 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
I know, I know guys... I'm gonna try to get the tune in the next couple of weeks.
Old Jul 16, 2006 | 10:38 PM
3hree5ive0ero's Avatar
3hree5ive0ero
Retired Admin
waiting results
Old Jul 17, 2006 | 06:05 AM
ATL_Red_G35's Avatar
ATL_Red_G35
so in another word
MREV2 and 5/16" Spacer will cause the car to run lean and you'd DEFINITELY need a tune?
Can someone please confirm this?
I've yet to install mine.
Old Jul 17, 2006 | 06:15 AM
masterj26's Avatar
masterj26
Originally Posted by ATL_Red_G35
so in another word
read this:
https://my350z.com/forum/intake-exhaust/188419-mrev-v2-independent-dyno-tested-on-bone-stock-287hp-motor-wired-24-7-s-05-touring.html
thats the full article where i got the quotes from.
Old Jul 17, 2006 | 01:53 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
so in another word
No, it's not "definitely" . Not every car will behave exactly the same way. Why? Because our ECU is a black box that not many people understand fully.
Old Jul 17, 2006 | 02:17 PM
one350zfan's Avatar
one350zfan
Here's my .02 - my buddy got the 5/16 spacer and was very pleased with the results. He later got a utec with tuner and tuned it himself with advanced timing and spot on A/F ratio. He was order #80 something on the mrev2 and the results after that install were less than pleasing. Now I know we never put it on the dyno but after the mrev 2 install his A/F ratio was the same and after data logging he felt no need to re-tune. We race all the time and frankly the mrev2 did nothing. After looking at the mrev2 i decided to lower the front two runners on my lower plenum. The results were negligent! A week later I received my used skunk2 spacer from audiblemayhem and after that install I noticed a huge gain. Top end was sick and I chirp going into third on my 275's. Its our belief that the spacer is a much better mod for the money and ZTampa's experience with the utec proves that adding the mrev2 to an already existing spacer will not change air fuel in some cases. However it was running a tad lean just with the spacer before he tuned it with utec
Old Jul 17, 2006 | 02:25 PM
ATL_Red_G35
thanks guys.
hm.....interesting feedback. What other bolt-ons do you have with the spacer/mrev machining?
Old Jul 17, 2006 | 03:28 PM
one350zfan's Avatar
one350zfan
injen ses exhaust, stillen TP's, pop charger, sun hyper force system, short shifter on a base 03. I ran a 13.9 a month ago in 95 degree temps before the mrev2 and spacer. Were going back in a couple of weeks to see if any gains. The way the car feels now I expect better times
Old Jul 17, 2006 | 03:46 PM
ATL_Red_G35
Thanks for the quick reply.
How hard is it to self tune the Utec? I haven't work with it before but have experience in tuning Honda's ECUs.
Old Jul 17, 2006 | 06:36 PM
Nismo 350z's Avatar
Nismo 350z
I think the best option would be getting the MREV2 with a spacer and then getting the car tuned i.e. reflash, UTEC, Emanage. Thats what Wired said. So for me do I need to reflash again by adding this combo?
Old Jul 17, 2006 | 06:55 PM
masterj26's Avatar
masterj26
i think im just gonna get my unichip installed and tuned without it and add the spacer in the near future and get it retuned
Old Jul 18, 2006 | 01:08 PM
one350zfan's Avatar
one350zfan
Its your money!
NissanZcrazy
Nov 2, 2015 06:03 PM
seagrasser
Oct 11, 2015 03:27 PM
FromGtoZ
Sep 20, 2015 03:41 PM
