Want to clear this MREV thing up one last time..
Old Jul 18, 2006 | 11:45 PM
dingobiatch's Avatar
dingobiatch
Default Want to clear this MREV thing up one last time..
I'm making this as straightforward as possible:
Which would be best on a REVUP '06 z?
-MREV+
-MREV+ and 5/16 Spacer
-5/16 Spacer
If the answer is the MREV+ and 5/16 spacer, are the gains significant enough to spend the extra $250 or so to get it?
(I've searched this a lot, and I've posted about it a few times, but I need a straightforward answer)
Old Jul 19, 2006 | 11:16 AM
Hydrazine's Avatar
Hydrazine
MOTORDYNE-MY350Z SPONSOR
-MREV+
-5/16 Spacer
If you have the REVUP engine (in the 6MT) do both the MREV2 and the spacer together. Its definitly the best plenum mod you can do.
If you have a non-REVUP engine (in the automatic), do one or the other. You can always add the other mod later, but first get a dyno before doing the second mod. If your A/F ratio is in the 13's or lower, you can do the other mod. If your A/F is in the 14's or higher, get a reflash or engine management first.
Old Jul 19, 2006 | 12:49 PM
blkonblkprime's Avatar
blkonblkprime
what gains should be expected on the revup with both?
Old Jul 19, 2006 | 12:51 PM
97supratt's Avatar
97supratt
Hey Dingo,
If you sell your stock manifold I might be interested in purchasing it for boredom purposes. lol
BTW When you have a MREV or any version of it installed on your REVUP motor, you will have this grin on your face .
Old Jul 19, 2006 | 12:59 PM
ct350z's Avatar
ct350z
If You Have Both Of Them On A Non Rev-up, How Much Is Expected If You Have A Reflash Or Say Utec?
Old Jul 19, 2006 | 01:00 PM
97supratt's Avatar
97supratt
I think Wired24/7 is going to be dynoing his car soon. He has a 05' Non REVUP I think with the MREV2 +5/16" spacer and will be tuned with a greddy e-manage ultimate.
Old Jul 19, 2006 | 01:07 PM
2FastG354U's Avatar
2FastG354U
Tony, why can't you just add MREV2 + 1/2 spacer on a non-rev up motor?
Old Jul 19, 2006 | 01:10 PM
Kenk2's Avatar
Kenk2
Professional
I have the MREV2 and have the 5/16 spacer, will be installing this weekend. I have an '04 6MT. I will get dyno'ed after the install. I also have the UTEC, wideband tuner and remote switch en route and will be here within a few days. After I install that, I will get ANOTHER dyno, also posting results. I am hoping to clear some things up for alot of folks.
Old Jul 19, 2006 | 01:15 PM
blkonblkprime
does the mrev+ work well with an aftermarket plenum?
Old Jul 19, 2006 | 01:22 PM
masterj26's Avatar
masterj26
since your doing two dynos you should install the mrev2 then dyno then install the spacer and redyno and once again redyno after to UTEC to see the gains when tuned. whats one extra dyno. j/k would be nice to figure out the upside of the spacer and mrev2 on the 287
Old Jul 19, 2006 | 01:30 PM
ct350z's Avatar
ct350z
awesome, thats what i've been waiting for. i hope you get great game dude!!!!
Old Jul 19, 2006 | 01:37 PM
3hree5ive0ero's Avatar
3hree5ive0ero
Retired Admin
Shouldn't he get like 4 dynos in order to obtain best info? Before any mods, after a mod, after the remaining mod, after the tune.
Old Jul 19, 2006 | 01:45 PM
Kenk2's Avatar
Kenk2
Professional
I would but really... I just dropped like $1100 for the UTEC, wideband tuner and remote switch.. I need to keep the wife in check or she is gonna have my a$$
Old Jul 19, 2006 | 02:04 PM
3hree5ive0ero
Retired Admin
If you give me your mods, I can do those 4 different dynos for you. Of couse, I'd keep the mods, but hey you get the satisfaction of gaining knowledge.
Old Jul 19, 2006 | 02:10 PM
Kenk2's Avatar
Kenk2
Professional
OK great! I could always use a little more knowledge! Whats your shipping addy?
When you get the packages make sure you take a long..... hard..... sniff!
Old Jul 19, 2006 | 05:30 PM
ct350z's Avatar
ct350z
hahahahahahahaha you terrorist!!!
Old Jul 19, 2006 | 06:00 PM
Nismo 350z's Avatar
Nismo 350z
What if the AFR is set at 13.3? Can you run them together then? Because I reflashed and Tadashi set my AFR at 13.3 but I am running the Rev-up lower plenum. If I get the MREV2+spacer, do I need to reflash again?
Old Jul 19, 2006 | 06:02 PM
Nismo 350z's Avatar
Nismo 350z
Originally Posted by 97supratt
Hey Dingo,
Are you asking for the lower plenum? I have that on my car and if I do the MREV2, spacer, or a combination of the 2, I can sell you my Rev-up lower plenum. I have to see if I get more hp/tq from the motordyne stuff 1st. Besides you are local so I can sell it to u easy.
Old Jul 19, 2006 | 06:09 PM
Miraclekidjr's Avatar
Miraclekidjr
When you speak of 13's...what RPM exactly, because my A/F starts 14.5 @ 3K then hits 14 @ 4.4K, 13.5 @ 6 then ends at 13 at redline
Old Jul 19, 2006 | 08:33 PM
Hydrazine's Avatar
Hydrazine
You can. Higher peak, but it makes less area under the curve.
Every dyno to date shows the 5/16" spacer always making more area under the curve.
