stupid cold airs....for the last time
Old Aug 4, 2006 | 10:18 AM
JDM_ZED33's Avatar
JDM_ZED33
Default stupid cold airs....for the last time
yes ive searched and researched about cold airs vs. pop chargers...but i still dont understand people on here saying that pop chargers give you more power....wouldn't it be more logical that you can more power through colder air from the front bumper vs. hot air from the engine just like every car? theres never been a straight forward answer....and for those who say that pop or stock air box gives you cold air, where does the cold air come from, the little slit right below the hood? I've had cold airs in other cars and they were nothing but gains....dont understand y everyone went pop?
Old Aug 4, 2006 | 10:42 AM
dubbzdiggler's Avatar
dubbzdiggler
I screws up the throttle response with the cold air...I think it's too long or something. You get a ton of cold air with the pop charger bc if you look straight down it's all open and there are little vents where the fresh air and rush right up through.
Old Aug 4, 2006 | 10:53 AM
Jason@Performance's Avatar
Jason@Performance
Performance Nissan
air does not take very long to heat up... but the time it gets up through the aluminum piping, it heats up just the same...
Old Aug 4, 2006 | 10:57 AM
Alberto's Avatar
Alberto
Cranky FI Owner
Air is hot even if its from the bumper, people really think its cold air its not, its slightly cooler air than underhood. Now to put it simply try this and post your results.
Imagine you have 2 cups of water, and 2 straws. One is LONG say 12" the other is short say 4". Both are the same diameter, now if you could suck the water out until the cup is dry which one do you think would win? Same with the intakes IMO, and on my car Pop-charger proved 10whp better than an AEM and a Crawford plenum. Case dismissed...
Old Aug 4, 2006 | 10:58 AM
mikead_99's Avatar
mikead_99
I went with the PC, more because performance from any intake is minimal on these cars, so why pay more.
Regarding cold air with PC or stock, I won't say it's cold but it ain't bad. I've monitored intake temp with an ODBII tool and see less then 10 degrees over ambient when moving, but it climbs much higher at long stops. I don't know where the thermistor is, but a lot of that 10 degrees from engine heat soak and would be seen with a CAI as well, but can't say for sure.
Old Aug 4, 2006 | 11:44 AM
JDM_ZED33's Avatar
JDM_ZED33
thanks alot guys, now i understand the logic.......thanks
Old Aug 4, 2006 | 11:59 AM
DavesZ#3's Avatar
DavesZ#3
The air moves through the intake tube pretty quickly so it doesn't get much of a chance to heat up. It probably heats more in the plenum and intake manifold than anywhere else.
As mikead_99 pointed out, the temperature rise of the intake air is not that much. I measured it to only be about 5ºF at highway speeds. BTW - the temperature sensor is part of the MAF assembly.
Old Aug 4, 2006 | 12:00 PM
I pull cold air from behind the grill. The problem is that it is pulled through a hot metal tube.
Also consider the problem of dyno testing long ram: the car is stationary with no ram effect.
Old Aug 4, 2006 | 12:08 PM
Juanito350Z's Avatar
Juanito350Z
When I had a Z.. I made more than 10whp with my AEM intake, I thought it was the s*** till one day in the rain I had to drive slow if I wanted to keep moving. I installed the bypass valve.. and showed 8-9whp gains.. so its still not bad for an intake, even though I would suggest just droping in a K&N Filter.
Old Aug 4, 2006 | 12:21 PM
jtoddj's Avatar
jtoddj
can you convert an aem cold air into a short version? Im not sure if theres enough room to put the filter on the tube?
HyperSprite's Avatar
HyperSprite
Mad Scientist
Sadly, this wont be the last time for "stupid cold airs".
If you get the Popcharger, make sure you don't run the car up to 100 and drop it in to neutral (this should not be done in any case, regardless of what intake you choose but), it seems people do it anyway and Zs with Popchargers tend to stall.
Just so you know what to expect when it happens, all the warning lights will come on, your steering will get stiff, and you will have one shoot at the brakes while they still have vacuum, after that, they take a lot more effort than the original posters search, so make the first stab count.
Chris
teh215's Avatar
teh215
Are you saying that a sorter pipe flows more? Unless you can specifically site a scientific principal, I'm throwing the flag.
Old Aug 4, 2006 | 07:53 PM
DavesZ#3's Avatar
DavesZ#3
What Alberto is trying to say is that the shorter pipe has less drag or friction loss. Less loss means more gets through for the same amount of work.
Old Aug 5, 2006 | 08:22 AM
slam's Avatar
slam
I just installed a popcharger on my '06 yesterday. Went for a drive and when the tach swept past 4,000 I had a huge grin on my face...the sound is just intoxicating.
Old Aug 5, 2006 | 08:52 AM
rotaryrocket7's Avatar
rotaryrocket7
To add to the point the air velocity is what can be greatly affected by length and diameter.
Very similar to how you change intake runners (removing length can decrease torque...)
Old Aug 5, 2006 | 02:06 PM
sokudo9l6's Avatar
sokudo9l6
get a Varis airduct if you want MORE cold air
Old Aug 6, 2006 | 07:31 AM
nathanwl2004's Avatar
nathanwl2004
I'm not an engineer or anything but I can see how the shorter intake would be better for throttle response. it takes less time for air to travel the length of the shorter air intake therefore it would take less time for the fresh air to reach your engine.
just a theory.
Old Aug 6, 2006 | 09:18 AM
pawnmarty's Avatar
pawnmarty
Default cold air
i would bet the big venturi (the silver funnel shaped thing under the filter) has more to do with increases in power than the filter etc. air will flow along that smoothe curve much better than a 90 degree corner found at the filter end of most cold air intakes.
Obadabot
Jun 18, 2023 11:31 PM
lapham3
Oct 7, 2022 03:15 PM
