Popcharger cleaner
Old Aug 5, 2006 | 01:50 PM
Cannysage's Avatar
Cannysage
Default Popcharger cleaner
how do you guys clean it? do you guys use the spray? I can just use soap and water, right? would the K&N filter cleaner work as well?
Old Aug 5, 2006 | 01:56 PM
gabez33's Avatar
gabez33
yeah Use the k&n recharge kit, it comes with a cleaner and oil....and yes you HAVE to use the oil...unless you buy the new AEM dry flow filter....I thinking about getting it...
Old Aug 5, 2006 | 01:59 PM
Cannysage's Avatar
Cannysage
cool, do they have them at pep boys? Also, I have about 15k miles on the pop. they say 30k before cleaning.. any thoughts?
Old Aug 5, 2006 | 02:05 PM
Cannysage's Avatar
Cannysage
I've found this on the web
SERVICING YOUR POP-CHARGER FILTER ELEMENT:
1. Remove the element from the POP-Charger aluminum venturi
and shake out any loose dirt.
2. Spray the element liberally with a water based cleaner like 409,
Simple Green, or laundry detergent mixed with warm water.
Basically any cleaner that could be used to remove grease from
a cotton tee shirt without damaging it.
3. Rinse the element with low pressure (IE. open ended garden
hose slightly opened) water from the inside outward.
4. Dry the element by shaking or swinging it to remove the
majority of water and allowing it to final dry naturally. No heat or
compressed air!
5. Spray an even coat of gauze air filter oil (most motorcycle,
performance shops or Jim Wolf Technology, inc.) lengthwise
along each pleat. Wait a few minutes and touch up any thin or
missed pleats.
6. Service intervals depend on the driving environment. Intervals
can be up to 50,000 miles or as short as one day for off-road
events. Generally the element can look pretty dirty and still be
working at a high efficiency since new particles continue to stick
to the previously trapped particles. If you are not sure, remove
the element and shine a light from the inside. If you can’t see
the light from the outside or it is dim, it’s time for service. Use
caution when cleaning or servicing car batteries located near
the filter, as battery acid residue will eat holes in the element.
Old Aug 5, 2006 | 03:12 PM
gabez33's Avatar
gabez33
cool, thanks...I didnt know I could use 409 and stuff that removes gease,....but yeah they have it at pep boys..comes with cleaner and oil for about $10....it lasts quite a while too...
Old Aug 5, 2006 | 04:58 PM
Jason@Performance's Avatar
Jason@Performance
Performance Nissan
you can get the K&N oil / cleaner at any pep boys / auto parts shop...
we also have them available here as well as on our web site...
http://mynismo.com/products/?id=2986
Old Aug 5, 2006 | 05:36 PM
GMZ's Avatar
GMZ
Theyre like 8.99 at walmart.....
Old Aug 7, 2006 | 06:00 PM
paulbk's Avatar
paulbk
I used 409 as well.
If I could go back, I'd definitely use the K&N oil instead.
I purchased the JWT oil off their site
Came out to almost $30 - not worth it for the blue color
pslamp32
Feb 8, 2017 09:07 AM
juang20
Intake
Sep 7, 2015 05:37 PM
ndelgro
Mid-Atlantic Marketplace
Sep 7, 2015 04:11 PM
AfroCreame
Cleaning & Detailing
Jun 15, 2006 03:40 PM
MrSpiffy
Mar 11, 2003 11:02 AM
