Spacers and MREV2 Question??
Old Aug 8, 2006 | 05:53 PM
MikeKondilis's Avatar
MikeKondilis
Default Spacers and MREV2 Question??
I have a 2005 Nissan 350Z Touring, I have some mods "check sig" and I am about to order my Motordyne 5/16" Basic Plenum Spacer Kit VQ35DE 350Z, plus I want the Motordyne MREV 2 VQ35DE 350Z combo??? Heard some good gains, cause I love to be N/A.
Which one is better the Iso Thermal Plenum Kit or the Basic???
Old Aug 8, 2006 | 06:07 PM
singh's Avatar
singh
_______________
Tony shoud be here any minute...
Old Aug 8, 2006 | 06:10 PM
VN_350z's Avatar
VN_350z
should gain about 50hp
Old Aug 8, 2006 | 06:12 PM
Hydrazine's Avatar
Hydrazine
MOTORDYNE-MY350Z SPONSOR
Hahaha! I guess I'm predictable.
Iso Thermal > Basic
The upper and lower plenum assembly will run 30' to 60' cooler with Iso Thermal.
Old Aug 8, 2006 | 08:14 PM
z-u-later's Avatar
z-u-later
Just installed my MD 5/16" plenum spacer with ISO thermal kit last night. I drove my Z to work today to find out what the hype is all about. Well, I was pleasantly suprise -- nice roar on the engine along with a harder pull than stock. I'm happy! And many thanks to Tony for his advise and reassurance prior to me doing the install!
Old Aug 9, 2006 | 05:41 AM
JNL's Avatar
JNL
if I install the MREV2 + 5/16th iso thermal spacer along with a z tube and Popcharger will if have to get my car tuned or can I just reset the ECU?
I drive an '05 g35 6mt coupe
Old Aug 9, 2006 | 05:44 AM
Gators2001's Avatar
Gators2001
I got the spacer alone and was impressed.... w/ the MREV would like to see the improvement
Old Aug 9, 2006 | 06:34 AM
MikeKondilis
thanks tony will order the combo sometime this month!
Old Aug 9, 2006 | 07:11 AM
Zincognito's Avatar
Zincognito
I didnt think the spacer and mrev2 together would do much together but i was impressed. Good choice!
Old Aug 9, 2006 | 07:53 AM
kpiskin's Avatar
kpiskin
I was reading in the other posts that the spacer and MREV2 really required a tune. Did you get one Zincognito? If so what did you do, and who tuned it for you? My only other performance mods will be my Nismo exhaust and Pop charger.
Old Aug 9, 2006 | 09:08 AM
Zincognito's Avatar
Zincognito
The tune is in a case by case thing. Although i havent dynoed it, i almost certain that im not running lean (just a hunch). I will be tuning it just for the sake of it with in ultimate e-manage around the 15th at Precission Auto. Not only does it rev faster but made my exhaust sound deeper. Let me know if you want to meet up and see for yourself....?
G
Old Aug 9, 2006 | 01:21 PM
Hydrazine's Avatar
Hydrazine
If you have a REVUP engine, you do NOT need a tune. The REVUP ECU easily adjusts to the MREV2 & 5/16" spacer combination no problem.
If you have the regular 287 engine, you may or may not need a tune. Check your dyno A/F results to know where your ratio is before using both together. Some will need a tune to do both. Some won't need a tune at all. ...And if you already have a reflash or good tune to the 12.5 - 13.25 A/F range, you are good to go!
Old Aug 9, 2006 | 04:05 PM
bofa's Avatar
bofa
So.. Tony... any package deals for us poor REVUP guys?
Old Aug 9, 2006 | 07:26 PM
Hydrazine's Avatar
Hydrazine
Sorry, GB's or specials are not available. The MREVS are a low margin item due to the parts involved.
OTOH...
With this combination, REVUP'ers will get the single *largest gain in NA performance that can be bolted on.
-> A minimum of 15HP and 18 TQ in the upper midrange. With a real potential for up to 20 HP and 30 TQ.
*(short of NO2 or FI)
Old Aug 10, 2006 | 12:46 PM
skyydiver's Avatar
skyydiver
Tony, the 5/16" spacer will be fine for the combo right? No need to move up to the 1/2" spacer? I would really like to keep my factory strut tower brace.
Thanks,
Joe
Old Aug 10, 2006 | 02:33 PM
z-u-later's Avatar
z-u-later
5/16" is what is recommended if you have the strut bar.
Old Aug 10, 2006 | 03:58 PM
bofa's Avatar
bofa
Good point.. as always.
Old Aug 10, 2006 | 05:58 PM
Hydrazine's Avatar
Hydrazine
Yes. 5/16"
Its definitly the best option for the Z.
Old Aug 10, 2006 | 07:16 PM
VN_350z's Avatar
VN_350z
Originally Posted by Hydrazine
Yes. 5/16"
i have 287 hp engine, what would you recommend? MREV2+5/16 spacer? Will i be able to keep the stock strut?
Old Aug 10, 2006 | 09:47 PM
Hydrazine's Avatar
Hydrazine
You will be able to keep the strut bar.
But for the 287 engine, add one or the other first. Then get a dyno. If you are not running lean, you can add the other.
