Oil in intake manifold?
Old Sep 13, 2006 | 10:57 AM
plumpzz's Avatar
plumpzz
Default Oil in intake manifold?
I took my intake manifold off to switch it off for a crawford and noticed oil all over the inside of my intake manifold. It wasn't much, maybe 2 spoons througout the whole manifold, but this all happened over 3k miles. Is this normal?
Old Sep 13, 2006 | 11:04 AM
You mean the top of the plenum? Yes its normal.
BTW the MREV++ in your signature is a modified lower plenum right? And you are adding the Crawford upper plenum. The results will be interesting. Let us know how the car runs. Thanks.
Old Sep 13, 2006 | 11:05 AM
sq40's Avatar
sq40
Its called Blow-Throgh, Its normal.
Old Sep 13, 2006 | 11:09 AM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
pretty normal, it might be a good idea to clean it every 30k miles or so.
JWT popcharger doesn't keep your plenum as clean as, say, OEM paper filter.
Old Sep 13, 2006 | 08:30 PM
plumpzz's Avatar
plumpzz
Its not oil from the popcharger or outside. Its blowby. I didnt think it would be this significant.
And davidv, the results are no different from my SSV sadly. I can tell im in need of a tune because i backfire alot (every shift and every time i rev slightly) and when i go WOT, theres NO fuel or thick black smoke coming outg the pipes, meaning its lean at WOT. Headers+UTEC+Tune next spring probably..
Old Sep 13, 2006 | 08:53 PM
dovla's Avatar
dovla
Default oil catch can?
Like many on g35driver site, after seeing oil there for second time I made me oil catch can, or you can buy one.
lapham3
Oct 7, 2022 03:15 PM
apex locator
Jul 23, 2021 02:27 AM
Sleeper_Z
Sep 30, 2015 10:25 AM
