JWT Popcharger problem (HELP)
Old Oct 5, 2006 | 04:08 AM
Tay350z's Avatar
Tay350z
Default JWT Popcharger problem (HELP)
Hey guys,
This has happened to me twice and was wondering if anybody else has had this problem or has suggestions on what I can do.
Well anyway, the filter part on my Popcharger keeps falling off. Not the whole part including the metal, but the filter comes off the metal and I see it just sitting in my engine bay. This scares me because I don't know how long I was driving without a filter!
Anybody have any suggestions? Thanks.
Old Oct 5, 2006 | 04:37 AM
davidf's Avatar
davidf
Did they not include a filter clamp? If theres no clamp any autozone will have one.
Old Oct 5, 2006 | 07:48 AM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
Tighten the clamp it's not supposed to be held on there with magic
Old Oct 5, 2006 | 08:11 AM
Combat350z's Avatar
Combat350z
Lol you mean all this time I thought magic elves were holding it on I was wrong.
Seriously there is a metal clamp that you can tighten to keep it on there. I had to do the same bc mine fell off as well. Plus over time you may just need to check especially if there are dramatic changes in whether
Edit: Yay 200 post yut
Old Oct 5, 2006 | 10:04 AM
bam025's Avatar
bam025
yea, it happened to me, car was ideling all funny, so I popped the hood and found the filter just laying near the front bumper. The clamp had come lose. Just re-tighten it, and check on it every now and then...
Old Oct 5, 2006 | 10:31 AM
ZlleH's Avatar
ZlleH
The above item(worm screw) should be put around the end of the filter that goes over the aluminum base. After which you should tighten it with a screw driver. This was mentioned in the instructions that came with the popcharger.
Originally Posted by Tay350z
Hey guys,
Old Oct 5, 2006 | 10:42 AM
stiv's Avatar
stiv
Sometimes, if there's too much filter oil on the inside of the rubber section, it'll slip off even if your clamp is tight.
I would get a clean cloth and wipe off the excess oil and then re-tighten the hose clamp.
If you do this, it should stay on.
Old Oct 5, 2006 | 10:48 AM
Eazzy's Avatar
Eazzy
Hey guys,
Well ---I doubt that u left the clamp off but if u did, slap ur self.
Wipe down the inside of the rubber part that goes over the tube with some Lacquer thinner and the tube it self, to remover any oily residue. Wipe it dry and reinstall with a clamp u know is good. make sure it is slid on atleast the depth of the filter clamp area. That should do it.
If its FILTHY dirty a small normal engine back fire will knock them off.
Thanx stiv --I type slo
Old Oct 5, 2006 | 11:20 AM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
Just some rubbing alcohol would work too.
Old Oct 5, 2006 | 12:26 PM
Eazzy's Avatar
Eazzy
True but if u do get the 91% rather than the 70%----Drugstores have it
Uriyo_
Sep 8, 2021 08:46 AM
