Maf Sensor? Clean
Old Oct 23, 2006 | 01:38 PM
thirty5ounces's Avatar
thirty5ounces
Default Maf Sensor? Clean
How exactly are you supposed to clean it. I have an electronics cleaner from radio shack. Do you unhook the battery to reset ecu while doing the clean, jsut unplug and clean the whole MAF sensor or is there a sertain place on the MAF sensor you are supposed to clean?
Old Oct 23, 2006 | 02:55 PM
Mathys's Avatar
Mathys
Just unhook the negative cable from the battery, remove the MAF sensor and spray the 'open' part where you see some metal kind of sensor.
Old Oct 23, 2006 | 03:51 PM
thirty5ounces
sounds good thanks
Old Oct 23, 2006 | 04:44 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
since the MAF is a hotwire style sensor, I'd make sure the car is cold before cleaning it as a precaution. you wouldn't want to create thermal shock and break something.
Old Oct 23, 2006 | 05:58 PM
zdotcom's Avatar
zdotcom
Here is a good link to check out. There are job specific products you can purchase.
http://www.crcindustries.com/auto/co...x?PN=05110&S=Y
liqalu04
Jan 2, 2022 12:58 PM
350Z_Al
Oct 29, 2020 07:44 PM
_bit
Oct 2, 2015 07:49 AM
Sleeper_Z
Sep 30, 2015 10:25 AM
