MRev2 + spacer + crawford upper
Old Nov 3, 2006 | 03:15 PM
akcraig85's Avatar
akcraig85
Default MRev2 + spacer + crawford upper
is it possible to use all of these, or is it one or the other. i know you can use the MREV2 + the spacer, but havent found anyone with the crawford upper with those. i did search and couldnt find what im looking for. thanks in advance.
Adam
Old Nov 3, 2006 | 03:27 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
Spacer + crawford = diminishing returns and not worth your money.
Also, if plenum volume is too big, you lose some throttle response.
Old Nov 3, 2006 | 03:32 PM
akcraig85's Avatar
akcraig85
what about for turbo applications
Old Nov 3, 2006 | 07:59 PM
undrgnd's Avatar
undrgnd
These hypothetical questions have become ridiculous. What if I had this, and how much would I make if I had that. Search, if you don't find it, buy the damn thing, dyno it, and tells us so we'll all know next time.
Old Nov 4, 2006 | 08:30 AM
ISMSOLUTIONS's Avatar
ISMSOLUTIONS
Nope - you either do spacer or a plenum - not both, unless you do MREV+ or MREV2 as well.
Too much volume not only gives you less HP overall, but forces lean conditions.
Technically, if you ran large injectors, return fuel system and a large fuel pump, a great tune - you COULD see gains with increasing the plenum volume.
HOWEVER - you'd be limited to the amount of volume the heads and valves would and could process - so you'd need cams and head work as well to maximize this mod.
Pretty expensive - and not really worth it. The factory plenums with MD mods are the most efficient out there...plenum replacements like Kinetix and Crawford give the same results as the MD line, if not slightly lower - but with less chance for a leaks as you don't have the additional gaskets from the spacer to contend with...but that is such a minor concern.
Rick
Old Nov 4, 2006 | 08:44 AM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
Won't matter very much at all. But how about getting the turbo first and *then* worrying about minor details like plenum spacer
Old Nov 5, 2006 | 12:46 PM
akcraig85's Avatar
akcraig85
well im doing little things on the way to the turbo. i know im going to turbo so pointless to do something im just going to have to turn around and sell. thanks for the input guys.
why reply to a post and say search when in my original thread i said i searched and couldnt find the info i was looking for. i guess its a easy way to get post count up though.
Adam
Old Dec 12, 2006 | 06:19 AM
Question
What did you order?
Old Dec 12, 2006 | 07:22 AM
akcraig85's Avatar
akcraig85
i did the 5/16 iso plenum spacer
Old Dec 12, 2006 | 07:30 AM
Thumbs up
Old Dec 12, 2006 | 07:55 AM
97supratt's Avatar
97supratt
This is the same as, "what if I install 3 plenum spacers?". The answer is simple, DON'T!
There is no point. You will not see gains. You will see a loss. It's a waste of money. But hey, if you are bored and have extra money to burn then by all means, be my guest.
Old Dec 12, 2006 | 08:00 AM
RBlover69's Avatar
RBlover69
mrev2 , 5/1/2 spacer call it a day on a revup
Old Dec 13, 2006 | 03:10 PM
garyovich's Avatar
garyovich
I have a very similar question as the OP. I just picked up an 06 with revup. I still have the crawford polished upper from my old Z. I plan on installing it soon (love the look and performance). being a revup should i get a new lower also, or does the crawford upper suffice? thanks
Old Dec 13, 2006 | 03:25 PM
Jay'Z's Avatar
Jay'Z
I was reading the thread healine and thinking flamethrowers would be out.. but not really....
wait what if i got the 5/16 spacer+skunk2 spacer+mrev2+kinetix v+ .. what would that do?
Old Dec 13, 2006 | 06:36 PM
Hydrazine's Avatar
Hydrazine
MOTORDYNE-MY350Z SPONSOR
Hahaha! Some of you guys are pretty damn funny. This board makes me laugh all the time with all the caustic sarcasm.
To answer the question:
No. Just do one upper plenum mod and you are done. You may or may not be able to fit a Crawford plenum on top of the spacer but I seriously doubt it will have any real world additional gain.
The MREV2 will make good gains on a REVUP engine and it will be even better when used with any kind of upper plenum mod. Cast plenum, plastic plenum, aluminum spacer, plastic, angled or straight.
But don't waste your money or your strut bar by stacking a plenum on top of a spacer.
Old Dec 13, 2006 | 06:54 PM
garyovich's Avatar
garyovich
yeah, crawford upper plenum won't accomodate stock strut bar by itself, i wonder how many spacers you'd have to put under it before you have to get one of those beautiful stillen hoods?
Old Dec 13, 2006 | 08:28 PM
RBlover69's Avatar
RBlover69
actually u dont have to now u can just wait for a 07z lmao . The horror.
Old Dec 14, 2006 | 07:38 AM
akcraig85's Avatar
akcraig85
its funny how all the responses came a month after the OP.
Old Dec 14, 2006 | 08:22 AM
NA&CH's Avatar
NA&CH
We need to make a "what works on your car" for the plenums, spacers, lower plenums, etc.
It is getting crazy with all the options and trim model cars. revup non rev.
Just a thought. Sticky it and call it a day and close all plenum threads.
So anyway whats the best for non revup 03
Old Dec 14, 2006 | 10:00 AM
IIQuickSilverII's Avatar
IIQuickSilverII
5/16" .
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
