Horsepower estimation?
Old Nov 9, 2006 | 07:44 PM
Metal Heart's Avatar
Metal Heart
Default Horsepower estimation?
I have looked extensively into mods of the F/I variety... So now I've decided to go N2O with N/A mods...
I know what ther nitrous will do with the car, but I'd like an approximation of what the following bolt ons will do...
-Intake Plenum Spacer
-MREV lower plenum replacement
-UTEC management + tune
-Headers
-Resonated Test Pipes
-True Dual Exhaust
-Cams (not sure what brand yet)
-Valve Spring/Shim kit
Also ... I know with said spring/shim kit I should be able to rev to 8k (or close to)... Where's the powerband going to really kick in? 4k? 4.5k?
Thanks
Old Nov 9, 2006 | 08:31 PM
doc10374's Avatar
doc10374
I'll give my guesstimate first. I'm thinking with a good tune you should be able to put down about 270-280'ish + whatever you spray with the N2O
Old Nov 9, 2006 | 10:19 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
If you get the right cams for the high RPM range, then I wouldn't be surprised to see close to 300whp peak (with some nice tuning)
Old Nov 9, 2006 | 10:52 PM
Metal Heart
And what does one consider the "right cams"?
Old Nov 10, 2006 | 09:31 PM
Metal Heart
Maybe I should post this in tuning instead?
Old Nov 11, 2006 | 10:23 AM
Old School's Avatar
Old School
Shift_Boost
I'm guessing 280whp....if you're gonna do the cams and valves, then you might as well do the whole head (both of course - PP, guides, retainers, etc). You could port & polish for another $400-500. If you get the heads done, you'll be in the 300 range...give or take 10whp.
Old Nov 11, 2006 | 11:08 AM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
It really depends on what dyno you use. If you havent installed these mods yet, I would recommend getting a baseline from your local dyno. Make sure to return to the same dyno for subsequent testing.
The mods you listed, with tuning, typically yield about 30-40whp improvement. That adding nitrous to the mix, will add xx whp.
Old Nov 11, 2006 | 03:15 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
I would take a look at GT motorsports N/A & S/C cams... they have a grind that is unique to any others.
They're new, so no one has tried them yet. But a lot of R&D seems to have gone into them.
There is a thread about this in the forced induction forum
Old Nov 11, 2006 | 04:11 PM
dTor's Avatar
dTor
With the exception of the cams/valvetrain, according to the before/after thread elsewhere in this section, you're looking at a 16 rwhp gain, with tuning.
Old Nov 11, 2006 | 04:22 PM
extreme4377's Avatar
extreme4377
With a fulle exhaust system(headers, TP, and catback), intake, mrev2, and a tune, you'd only get 16RWHP? Whered you get that number from? The Fast Intentions Intimidator exhaust and test pipes gained 15hp without a tune on a baseline Z.
Old Nov 11, 2006 | 07:53 PM
dTor's Avatar
dTor
https://my350z.com/forum/intake-exhaust/229820-forged-performance-and-sharif-i-m-calling-you-out.html
Currently, one thread below this one.
Workshop12
Mar 23, 2020 01:45 PM
Dymsi
Sep 29, 2015 11:32 AM
torchkc
Sep 11, 2015 08:26 PM
EnjukuRacing
Sep 11, 2015 08:34 AM
EnjukuRacing
Sep 11, 2015 08:30 AM
