Need help with SES light
Old Nov 16, 2006 | 06:56 AM
drap660's Avatar
drap660
Default Need help with SES light
Got test pipes installed along with a Borla Td and MREV2, 5/16 combo and a Utec... After awhile my SES light came on... I know its a test pipe issue.. Just need to know where I can purchase a kit that can just bolt on and fix this... Any help will be appreciated...
Old Nov 16, 2006 | 07:09 AM
Z04's Avatar
Z04
check the sponsor page
Old Nov 16, 2006 | 07:17 AM
drap660's Avatar
drap660
All I see are sponsors... No specifics
Old Nov 16, 2006 | 07:20 AM
Mike Wazowski's Avatar
Mike Wazowski
try the search function....
edit: I did a search just now and found what you are looking for. But since you have yet to use it. I will not give you the link.
Old Nov 16, 2006 | 07:23 AM
drap660's Avatar
drap660
I have looked and found some threads but cant find anyone str8 up selling a kit that just bolts on
Old Nov 16, 2006 | 07:25 AM
Mike Wazowski
good lord. if you found the threads you would know you only need to go to Autozone and spend $8.00 for what you need "that bolts right on"
Old Nov 16, 2006 | 07:27 AM
michaeljr6's Avatar
michaeljr6
it's called defouler....or something like that..it should solve your porblem
Old Nov 16, 2006 | 07:28 AM
Mike Wazowski
non-fouler
Old Nov 16, 2006 | 07:34 AM
drap660's Avatar
drap660
Ok.. I think I have it... Now one more probably dumb question... If I remove the negative terminal to try and rest my ECU will my utec maps go away??? And how is the pedal ECU reset trick...
Old Nov 16, 2006 | 07:37 AM
Mike Wazowski
https://my350z.com/forum/showthread.php?t=204022
just go to autozone and borrow their code reader and erase the code.
Old Nov 16, 2006 | 08:16 AM
drap660's Avatar
drap660
Ok, I understand that but do you know if reseting My ECU will erase or mess with the maps on my utec????
Old Nov 16, 2006 | 08:29 AM
Mike Wazowski
I dont run utec so I couldn't say. I would PM sharif and he would know.
Old Nov 16, 2006 | 10:31 AM
drap660's Avatar
drap660
Ok, so I took it to autozone and the eror thats coming up is P0174... Does this have to do with the test pipes????
Old Nov 16, 2006 | 11:01 AM
drap660's Avatar
drap660
I just heard from somebody that it maybe a dirty MAF sensor ( I just added a pop charger and maybe its picking up some dirt)... Is the MAF sensor the sensor right behind the pop charger on the intake tube???
Old Nov 16, 2006 | 11:22 AM
Mike Wazowski
P0174 OBD-II Trouble Code
Technical Description
System Too Lean (Bank 2)
Old Nov 16, 2006 | 11:30 AM
drap660's Avatar
drap660
So does anybody have any idea what that could be??? This has nothing to do with the test pipes right??
Old Nov 16, 2006 | 11:33 AM
Mike Wazowski
that is the test pipes. non-fouler will fix the problem.
my suggestion would be to get the non-foulers and a code scanner. The scanners are very cheap now days you can get one for like $50.00.
Old Nov 16, 2006 | 12:09 PM
drap660's Avatar
drap660
Are you sure its the test pipes...
Old Nov 16, 2006 | 12:17 PM
Mike Wazowski
yes
Old Nov 16, 2006 | 12:19 PM
drap660's Avatar
drap660
Thatnks for all your help and bashing... They are well appreciated...
loudtoyz
Apr 6, 2023 04:52 AM
Uriyo_
Sep 8, 2021 08:46 AM
350z82
Oct 1, 2015 06:25 PM
Sleeper_Z
Sep 30, 2015 10:25 AM
samansharif
Sep 25, 2015 12:31 PM
