Installing a CAI on a 06 Z
Old Dec 1, 2006 | 08:09 PM
CaliTouring's Avatar
CaliTouring
Default Installing a CAI on a 06 Z
Ok, I did a search and didnt find anything so dont tell me to search.
I want to know if anyone ever put up a post on how to take the bumper off and install the intake. The reason why I dont want to go get it installed is because i want to enjoy working on my car a little bit and second is because I dont want to pay 120 bux for installation. So if anyone know or has a pix on how to do it I would greatly appriciate it.
THANX!
Old Dec 2, 2006 | 03:47 AM
Question
Which intake?
Old Dec 2, 2006 | 04:24 AM
jeff_chen0209's Avatar
jeff_chen0209
there but not sure if 06s are the same....
Old Dec 2, 2006 | 06:44 AM
spacemn_spiff's Avatar
spacemn_spiff
Originally Posted by davidv
Which intake?
+1 and how cold does the air get when it goes thru the intake?
Old Dec 2, 2006 | 07:33 PM
CaliTouring
Which intake?
Injen
Old Dec 2, 2006 | 07:34 PM
CaliTouring
can someone confirm that its the same for the 06?
Old Dec 2, 2006 | 08:08 PM
undrgnd's Avatar
undrgnd
That's too funny. I guess it depends on where you have the Chilled Intake thermostat set at.
Old Dec 2, 2006 | 08:36 PM
mikead_99's Avatar
mikead_99
I didn't do a compare to the page jeff_chen0209 gave you, but this is from the '06 manual. It should get you where you want to go with this.
Old Dec 2, 2006 | 09:53 PM
Hydrazine's Avatar
Hydrazine
MOTORDYNE-MY350Z SPONSOR
You don't need to take the bumper off. (At least with the AEM)
Old Dec 2, 2006 | 11:35 PM
CaliTouring
Thanx a grip load! looks complicated but im lookin forward to tryin lol
Old Dec 3, 2006 | 07:46 AM
TreeZ's Avatar
TreeZ
listen to the man^^. i just removed the wheel and peeled back the fenderwell lining to access that area. i've had the bumper off before (to replace it), it is much easier to leave it on.
Old Dec 3, 2006 | 12:04 PM
BaTMan_4's Avatar
BaTMan_4
Why CAI?? Just leave it as SRi....this has been talked about before where the CAI at times even takes some small HP away....SRi is more effective. I've raced 2 Z's with Injen in CAI mode and i beat them both with my Injen in SRi...no joke....and you save having to take the bumper off
Old Dec 3, 2006 | 02:08 PM
CaliTouring
i neva thought of that ima try that first. thanx
Old Dec 3, 2006 | 03:24 PM
nasty50's Avatar
nasty50
I have the same intake injen cai.I installed it with the short ram at first its sounds louder(which is good).I was continplating how to take off the bumper also.so after a week I decided to go on with it,left the bumper on just took off 3 clips on the top of the bumper then I was able to take out the stock scoop.the hard part is running the rubberized injen tube thru the hole and down.so what I did,I greesed up the tube enough just so iam able to manipulate it thru that opening.worked out good.only thing you got to think about is the rain or water from washing the car cus you'll definitely wet the filter element unless you get a air bypass.I commute with the car a lot mostly in freeway so with that cold air helps with the performance a lot.either sai,or cai you can definitely feel the difference from stock.goodluck.
Old Dec 3, 2006 | 06:40 PM
BaTMan_4's Avatar
BaTMan_4
^ from my understanding from researching this forum was that getting the filter wet is fine...the tube is waaay to far down and long for the water to do any damage....just don't get it sumerged in a puddle....now that is bad
Old Dec 4, 2006 | 12:13 AM
CaliTouring
ya I was thinking about the rain issue I was wondering if I should purchase some sort of covering for the cone or something but then i guess that defeats the whole purpose of the intake if I were to cover it. (just the front end of the intake not the whole thing lol)
Old Dec 4, 2006 | 01:27 PM
BaTMan_4's Avatar
BaTMan_4
^ you should be fine with rain hitting it....as long as its not large amounts where the whole filter is submerged
Old Dec 21, 2006 | 05:06 AM
Question
What did you order?
Old Feb 2, 2007 | 09:47 AM
joe645733's Avatar
joe645733
u dont need to take the bumper off. and u might have raced some retarded z's cuz ive seen a few dyno sheets with a couple hp gains.
the typhoon is what loses hp
Z King
Vendor Wanted
13
Oct 22, 2015 11:39 AM
