Just bought test pipes, what bolts do i need?
Old Apr 3, 2007 | 02:38 PM
sk26dett's Avatar
sk26dett
Default Just bought test pipes, what bolts do i need?
I just bought some test pipes off an other member, but they dont come with any of the hardware, could anyone tell me what size and type of bolt to use? From what i understand the upper bolts are attached to the cats, so all i would really need are the upper 3 bolts for each side, right?
Old Apr 3, 2007 | 03:33 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
Go to the hardware store and buy some stainless steel nuts and bolts that fit through the hole
header to cats : 3 bolts each side. if you have stock headers, 1 bolt is permanently fixed in place per side (and you will re-use the stock nuts), so you'd need 2 per side.
cats/TP to y-pipe: 2 bolts each side
Total: 8 nuts/bolts
Someone correct me if I'm wrong.
Old Apr 10, 2007 | 11:24 PM
sk26dett's Avatar
sk26dett
Thanks, that sounds good
Old Apr 10, 2007 | 11:36 PM
Machupo's Avatar
Machupo
can't reuse the hardware already in there?
Old Apr 11, 2007 | 12:14 AM
ARMSTRONGARMS's Avatar
ARMSTRONGARMS
make sure you get stainless steel! M10x1.5????for size,i'm having a brain fart.
Old Apr 17, 2007 | 11:16 AM
sk26dett's Avatar
sk26dett
thanks guys, got em on...wasnt too bad
Old Apr 17, 2007 | 09:39 PM
bacalhau16's Avatar
bacalhau16
Did you buy these with gaskets, or did you have to buy a set of gaskets.
I bought a set of used TP's off of a member, but they obviously didnt have gaskets. I would like to buy new ones, but from Nissan it was something stupid like $25 a gasket. Not really sure what to do!
Old Apr 17, 2007 | 09:42 PM
Nexx's Avatar
Nexx
ahh, you really dont need new gaskets. just reuse the stock ones. they are metal folks. numerous people have done this with zero problems.
Old Apr 17, 2007 | 09:52 PM
infiniteracing's Avatar
infiniteracing
Yeah I need gaskets for my stillen testies too. Anyone know where to get these?
Old Apr 18, 2007 | 12:04 AM
sk26dett's Avatar
sk26dett
i reused my stock ones, as Nexx said, they seemed perfectly fine.
Old Apr 18, 2007 | 06:57 AM
bacalhau16's Avatar
bacalhau16
Wow, thats pretty cool then. I may use a little bit of that high temp adhesive as well just to be sure. Thanks for the info.
issyz
Jul 2, 2017 03:04 PM
Fixxxercask
Nov 9, 2015 11:10 AM
Sleeper_Z
Sep 30, 2015 10:25 AM
codek
Sep 28, 2015 03:03 AM
