MREV2 and 5/16 ISO plenum spacer
Guys, this will be a newbie question..I did some research and couldnt find exact answer...I want to know if its a good idea to put both MREV2 and 5/16 ISO plenum spacer for my 05. My car is not the 35th version..so I have the non-rev up engine..the one has 287hp. Its also an auto. I heard some spacer will make the hood rub..Any detail info? I also want to know the gain in whp if I put both on..Thanks in advance folks!
I am not sure if I got it right in here, so for my "non-revup" engine, I should go with MREV2 first and it wont harm the top end hp gain. The spacer will help but little gain only and I should not only install the spacer as this wont make a noticeable gain in hp for nonrevup engine? Am I correct? So I should go with only MREV2 if I only want to spend around 500$. Will the sound of the engine change with the Mrev2? Any DIY picture of this installation? So this mod should go first than the header or test pipe? I already got the nismo exhaust..wanna make sure the next mod is the biggest band for the buck.
Originally Posted by whitenizmo
Thanks for the info, so which spacer will be able to fit will the stock strut? I dont want to put hood spacer or anything like that...
