removing the resonator/midpipe
Old Apr 23, 2007 | 09:28 AM
boostingdsm2s2k's Avatar
boostingdsm2s2k
Default removing the resonator/midpipe
anyone did this. does it sound good?
Old Apr 23, 2007 | 09:49 AM
MustGoFastR's Avatar
MustGoFastR
Some people tried this a long time ago. Sounded like crap, iirc. Lots of rasp.
Old Apr 23, 2007 | 01:35 PM
Z04's Avatar
Z04
sounds like a riced-out honda to be more precise
Old Apr 23, 2007 | 02:10 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
It's not a great idea. Plus cold air touching hot O2 sensors = bad. There are reasons your exhaust extends to the rear of the car.
If you want something loud as f0ck you might consider getting straight pipes fabricated at an exhaust shop... should not be expensive at all.
Old Apr 23, 2007 | 02:15 PM
halfass872's Avatar
halfass872
I removed my resonator and had a piece of straight pipe installed before i got my Nismo. It actually sounded pretty good! A little rasp, but it loudened it up nicely, so it was worth it. Just don't let em toos it, if you don't like it, you can spend $10 and have 'em put it back in.
Old Apr 23, 2007 | 02:17 PM
Do it. Let us know the results.
Old Apr 23, 2007 | 03:33 PM
jondimellow's Avatar
jondimellow
i did the exact same thing with my nismo. my neighbors defanitely don't like it. it is hecka loud. but with rasp when cold.
Old Apr 28, 2007 | 05:11 PM
iceburns288's Avatar
iceburns288
Bump... anyone have a reasonable estimate as to how much it would cost to have a new mid-pipe made? I have test pipes and a stock exhaust and I was interested in a little bit more noise while retaining the VQ sound. And of course, at a much lower price than buying a full exhaust! I'm also thinking of asking for someone's stock mid-pipe and having the resonator removed with a pipe welded in its place.
Old Apr 28, 2007 | 11:20 PM
Chad68's Avatar
Chad68
You still drive without it now?
I was asking about removing that pipe once too. Was wondering if the rasp increase and noise increase was similar to running test pipes?
Old Apr 28, 2007 | 11:58 PM
Chad68's Avatar
Chad68
I'm sure the OP was meaning to remove the midpipe and replace it with straight tubing, not remove it and leave a foot long gap in the exhaust LOL
I sure hope that's what he meant anyway.
Old Apr 29, 2007 | 12:02 AM
Chad68's Avatar
Chad68
**** now that's a good idea. I still have my stock exhaust. If the stock midpipe section is the same dimensions as the Nismo and bolts up cleanly, I will just remove the resonator from the old factory pipe, replace with straight tubing and bolt it onto the Nismo, instead of hacking up the Nismo pipe.
edit:
screw it I'm just gonna have them yank out the Nismo mid pipe and add the straight pipe next Sat. Will make sure I make it clear that it will need to go back if it sounds like crap though. Will let you know what I think it sounds like next Sat. The price is right whether it works out or not.
Old Apr 29, 2007 | 08:13 PM
jondimellow
yea i still drive without the resonator, straight pipe in place. its loud. there is rasp, but for the moment, i don't mind. it is kinda deceiving how loud it is, because in the cabin it doesn't seem that bad. ive had coworkers tell me they can hear my car a good 500-700 ft away. gota be careful for the popos tho.
if you are just driving normal, its noticeably louder than just the nismo. if you WOT, its LOUD. if you are in a parking garage and floor it, you will scare people.
Ive never had test pipes..... hope this helps.
Old Apr 30, 2007 | 07:51 PM
Chad68's Avatar
Chad68
Thanks man. So to re-clarify, does it rasp only when the engine and exhaust are cold or does it always rasp?
Wonder if a tiny resonator would help with the rasp if it's too bad, yet still maintain the higher DB levels.
Think I'm still gonna give it a shot. At least I can swap it back if I hate it.
Old May 1, 2007 | 03:49 PM
XuperXero's Avatar
XuperXero
Instead of removing my resonator. I cut the end of the midpipe where the muffler is and had a Y-pipe welded on with stock tips at the end. Sounds pretty nice, but still rasps when cold.
I've had people tell me it's loud and it's not that loud. Very mixed... I think I have a youtube video somewhere...
http://www.youtube.com/watch?v=YkFpYl5BeDc
edit: Excuse the comment at the end of the video
sales@czp
Sep 23, 2019 03:30 PM
3vilbunny
Jul 18, 2017 05:10 PM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
Depravity
Oct 1, 2015 04:49 PM
Cashwin
Oct 1, 2015 06:36 AM
