New Custom Plenum!!!!
Old May 16, 2010 | 12:20 PM
  #141
Jes-Z's Avatar
Jes-Z
I'm not sure if Mike still has the car. His GF had a baby a while back so I'm sure Mike is busy with his Family now. I haven't heard from him in almost 2 years.
Old May 16, 2010 | 12:54 PM
  #142
0jiggy0's Avatar
0jiggy0
Cast REVIVE!
Old May 16, 2010 | 03:10 PM
  #143
Legr19's Avatar
Legr19
He does still have his G; he rolled my fenders about 2 weeks ago and I saw it and the intake manifold, looks badass!
Old May 18, 2010 | 03:43 PM
  #144
Jes-Z's Avatar
Jes-Z
How is the spolier? lol.
Old May 18, 2010 | 04:42 PM
  #145
jonnylaw's Avatar
jonnylaw
I'm not sure if anyone brought this up or not, but without any supporting bolts in the middle of the plenum (like oem), won't in be prone to bending/collapsing under pressure?
Old Dec 14, 2010 | 06:59 PM
  #146
rpm06g35's Avatar
rpm06g35
Im still around jess just moved up to Connecticut for my next tour of duty. Im going to post up some stuff that i posted on driver.
Well several people have asked so i will add pics and narrate as i go. Hopefully this will help everyone if they decide to try and go this route. Talk soon guys
new top that was to be dsskyline before he backed out
ernests top
lil mike/marvins top
erics top (only one running modified rev up collector)
the original top that started it all
milled top of non rev up lower collector
milling a runner
Actually removing the top here. Milling was the most preventative way of reducing warp
decked and ported on left just decked on right
Old Dec 14, 2010 | 07:00 PM
  #147
rpm06g35's Avatar
rpm06g35
Now for the down low on porting. By stuffing the ports you can get the layout dye to make your removal of bulk material marks
In pics 1 and 2 I am spraying the dye from the bottom
in pics 3 and 4 notice the vague dye marks
in pics 5,6 and 7 you can see i chased the vague dye imprint with a sharpie to maximize idetification for max removal
blue layout dye used
rough cut removal tool
in pics 10,11 and 12 the removal of bulk
finished with the final of a 400 paddle wheel
Thanks for checking out guys
Mike
Old Dec 22, 2010 | 02:33 AM
  #148
t6378tp1's Avatar
t6378tp1
Has any of these ever been dyno'd
Old Dec 22, 2010 | 01:05 PM
  #149
rpm06g35's Avatar
rpm06g35
yes they have been dyno'd and the dyno# have ranged from 260's to 280. depending on the mods. Best result were with a u tech. pm me if you need more info. talk soon mike
Old Dec 22, 2010 | 03:21 PM
  #150
str8dum1's Avatar
str8dum1
interesting, i guess you also have to modify the gasket since that was included during the vague dye stage?
Old Dec 22, 2010 | 04:06 PM
  #151
rpm06g35's Avatar
rpm06g35
Gasket may need to trimmed up a little. The first set up i made on my car didnt need any trimming. With the middle and lower together (with gasket in between) the gasket didnt hang over. Each one is different it s all according to how much i cut out of the center. talk soon mike
Old Dec 22, 2010 | 05:11 PM
  #152
t6378tp1's Avatar
t6378tp1
pm sent
Old Dec 23, 2010 | 05:20 PM
  #153
ac419's Avatar
ac419
how much is something like this?
Old Dec 23, 2010 | 08:37 PM
  #154
rpm06g35's Avatar
rpm06g35
I dont mass produce this stuff. I have about 12 setups out there but usually do it for close friends. It takes about 12 hrs from start to finish. machine shops charge around 80 per hr. talk soon mike
Old Sep 10, 2011 | 07:33 AM
  #155
denchan350gt's Avatar
denchan350gt
original thread at end of post.
before was 5/16 spacer w/kinetix V5 and stock lowers
after was 1/2 spacer and modified lowers with stock top
I ran my PB with the 250hp tune 13.147@107.
http://g35driver.com/forums/intake-e...-manifold.html
350Z_Al
Oct 29, 2020 07:44 PM
Rowlett
Misc.
Oct 2, 2015 10:38 AM
