Mechanic says Cold air intake is a bad thing.. wtf?
Old Jun 18, 2007 | 12:53 PM
ickysz's Avatar
ickysz
Default Mechanic says Cold air intake is a bad thing.. wtf?
So I talked to this mechanic & I mentioned how I ordered a cold air intake, he then started rambling....
"Cold air intakes are bad for your car, when the manifacturer's created there cars, they put top notch parts in them, for example your intake & filter, there the best you can have in your car, if you had anything different it would be very dangerous" This is where he started talking about 18 wheelers.... " Ever heard of 18 wheelers losing control of there trucks, cant slow down?? Well same with your car, if you were to put a cold air intake in your car, the filter & valve are bigger than your factory one, there is such thing as not enough air & too much air, this would let to much air enter your intake, causing the carberator to blow wide open & you wouldnt be able to stop your car, even if you turned your car off, it would still be flying down the road!" ... Ok.... seeing how I already ordered an intake... and this guy is talking ****.. I was pretty pissed off & left.
I've never heard that a cold air intake is bad ... so what the hell??
Old Jun 18, 2007 | 12:58 PM
04DBZ's Avatar
04DBZ
wut the hell?? So i'm guessing the Nismo CAI is bad for our cars even though Nissan made it!
Old Jun 18, 2007 | 01:00 PM
stormcrow's Avatar
stormcrow
yes, those pesky carburetors on the VQ35 are notorious for being blown open by the cold air intakes! i can't believe you've never heard of this!
dude, stay away from alabama shade-tree mechanics... i'll wager he was dipping Skoal, wasn't he... had a mullet even?
Old Jun 18, 2007 | 01:02 PM
RedBullRR's Avatar
RedBullRR
Dam Mechanics in Alabama dont know Jack Man. LOL
Your not forcing air into your car making it more air, your just feeding your car colder air. Cold air equals better HP. Not saying it will give you HP just saying Cold air will keep your HP stable were hot air will make your car wimp out.
Old Jun 18, 2007 | 01:04 PM
6894kevin's Avatar
6894kevin
Was He A Short Bus Rider
WTF, if you ordered a part for a car then you should know all about the part and all about the car B4 you put it on. You don't have a carb, it's FI and a Z isn't an 18 wheeler.
NEVER go back to that guy and NEVER order something with out research.
Cheers
Kevin
Old Jun 18, 2007 | 01:05 PM
fairlady350z33's Avatar
fairlady350z33
time to change mechanics... the performance might not be as good due to the longer piping, but it def won't blow up your VQ.
Old Jun 18, 2007 | 01:07 PM
GalvatronType_R's Avatar
GalvatronType_R
While what that mechanic said is untrue, I will put something else out there. CAIs that use exposed filters increases your chances of heat soak and water ingestion. Also, on the Z and from what I've read here, since the Z already uses a CAI, there are minimal performance gains made by aftermarket intakes.
Old Jun 18, 2007 | 01:13 PM
dcmaxclub's Avatar
dcmaxclub
I think someone stole my carburetor. I've looked all around the flux capacitor and even in the improbability drive, and I just can't seem to find it anywhere ????
Old Jun 18, 2007 | 01:14 PM
dcmaxclub's Avatar
dcmaxclub
Seriously though, no new cars have come with carburetors in the US since the early 90's. You sure this guy was a mechanic?
and since when is there a valve in a CAI?
Old Jun 18, 2007 | 01:16 PM
06MagneticZ's Avatar
06MagneticZ
AHAHAH...ur carburator!
Old Jun 18, 2007 | 01:17 PM
cessna's Avatar
cessna
And somewhere, a village is missing it's Idiot.
Old Jun 18, 2007 | 01:18 PM
ickysz's Avatar
ickysz
He works as one... I've never had him do anything to my car nore will I ever ... & he DID have dip in his mouth, seriously... lol So someone says you lose performance gains since the pipe is so long? Thought the whole point was to gain? whats going on...
Old Jun 18, 2007 | 01:20 PM
Blue_Z's Avatar
Blue_Z
actually Nismo CAI isn't made by Nissan, it's an AEM CAI with a NISMO label.
Old Jun 18, 2007 | 01:24 PM
usmanasif's Avatar
usmanasif
LOL! This is good stuff!
stormcrow's Avatar
stormcrow
i knew it! *ahahaha* kinda surprises that he doesn't have a mullet, tho...
re: CAI... you'll find quite a wide variety of opinions on this subject... some people swear by them, others think they are crap... water ingestion is possible without a check valve...which most now come with... just don't drive through any mud puddles or ponds and you should be ok... just so you have my opinion, we in the southern states won't benefit from a CAI... which do you think is hotter...the air 3 feet above the roasting 140 degree asphalt or the air 6 inches above it?
Old Jun 18, 2007 | 01:29 PM
I heard that Neil Armstrong’s walk on the moon was really filmed on a Hollywood set. Is that true?
Old Jun 18, 2007 | 01:31 PM
Blue_Z's Avatar
Blue_Z
while I don't believe what the mechanic said about the carberuator, I can understand where he's coming from.
for example, I switched to JWT Popcharger and it's been fine. But for others, their engine would shut down when they'd put the car in neutral after driving over a certain speed. (don't ask why they would put it in neutral in the first place) Anyways, after doing more research it turns out that my JWT Popcharger sucks up too much hot air during daily driving and turns out that the stock 06 w/ velocity stack airbox which i had previously, is an all-around better option.
Old Jun 18, 2007 | 01:32 PM
Z-T's Avatar
Z-T
My experience with CAI's is that they're usually inefective at producing some, if any real gains in performance (unless you count sound as performance).
The way I see it, 1000's of testing hours, highly paid engineers and millions of $'s produced the Z's we drive - the mechanic has a point to some extent (for reliable, efficient, solid performance). Although I'm not entirely against CAI's, I think that $ is better spent somewhere else. Just my $0.02.
Old Jun 18, 2007 | 01:33 PM
ickysz's Avatar
ickysz
No no get this, I just called the nissan dealership I go to & asked them if they install cold air intakes, guy said.. "oh yeah, we've had a few, as long as the intake comes with instructions, I'm sure our guys can read them & figure it out"... haha! No thank you!
