Evap
Old Jun 27, 2007 | 06:46 AM
sean2006's Avatar
sean2006
Default Evap
hey i had to move the evap box to center and now the engine light is on ? everything is hook up.....any ideas? and i did search for it so chill
Old Jun 27, 2007 | 09:28 AM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
You probably messed something up while relocating it. Check all the hose connections, maybe you switched the location of 2 hoses or there could be a leak.
I've heard numerous stories of people messing up the relocation. Apparently it's rather fragile and/or "testy"
Old Jun 27, 2007 | 11:32 AM
ml3e's Avatar
ml3e
yah i have the greddy evo 2 and it really is "testy" just make sure everything is tied properly because i had a leak..
Old Jun 27, 2007 | 02:44 PM
VIZAGE's Avatar
VIZAGE
I had a leak also. Plus the harness that is located on the outside of the box was loose. It took me a week to find it. If you look at it closely, you'll see that it can rotate some. Make sure it's in the right postion. A slight offset can throw it off. Make sure there is no tension at all on the hoses and plugs. This was my problem. I couldn't believe it myself. Just something you might want to check out.
Old Jun 27, 2007 | 09:12 PM
sean2006's Avatar
sean2006
k thanks guys
Old Jun 28, 2007 | 07:21 AM
Datona Jess's Avatar
Datona Jess
I have to agree with the aboe
On my bracket it tended to slide slightly once I was driving..(turning hard)
This put pressure on one of the hoses, and that would set it off.
They are VERY touchy so just a little trial and error and you should get it...
Good luck!
Old Jun 29, 2007 | 01:00 PM
stylett9's Avatar
stylett9
I have this problem as well. I too my car to the dealership and they fixed it...but then the light came back on later in the day. It's ganna be some time before i can get back there, does this leak cause any damage?
Old Jun 29, 2007 | 06:42 PM
VIZAGE's Avatar
VIZAGE
No, it does not cause any damage. It's just a safety item for the help of less pollution. The EVAP is a charcoal filter the routes gas fumes threw it to help cutdown on pollution. As I was told.
dutchboy350Z
Feb 15, 2022 11:07 PM
sales@czp
Sep 23, 2019 03:30 PM
Dr.Paulyy
Jul 29, 2019 07:45 AM
VO...
Oct 4, 2018 10:50 PM
disturbed2483
Aug 5, 2009 05:54 PM
