how is 06 intake tube different
Old Jun 28, 2007 | 12:45 PM
SHT35T's Avatar
SHT35T
Default how is 06 intake tube different
Ok, I've been searching for this the past 3 days and came up that the 06 stock intake tube has better velocity. But, visually only by pics, the tubes from the non-revup and rev-up seem to look the same. How can you tell the difference between the 2.
(I have an 06 but sold the stock tube, I want to buy another one. I just don't want to be fooled by someone saying it is the revup when it's not)
Thanks
Old Jun 28, 2007 | 12:46 PM
ohSIXz's Avatar
ohSIXz
velocity stacks
Old Jun 28, 2007 | 12:59 PM
SHT35T's Avatar
SHT35T
sorry i'm a newbie...what does that look like?
Old Jun 28, 2007 | 01:09 PM
gothchick's Avatar
gothchick
Something like this:
Old Jun 28, 2007 | 01:40 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
03-05 intakes: small metal ring (after the filter, before the intake tube) that smoothes out the flow
06+ intakes: same thing, except as mentioned, it has a velocity stack (similar to what gothchick posted) which accelerates air coming into your intake tube.
HP difference: who the hell knows
Old Jun 28, 2007 | 04:38 PM
alexfair's Avatar
alexfair
just get whatever one and add a turbonator.
Old Jun 28, 2007 | 05:12 PM
rocks's Avatar
rocks
My altima had one. My 06 had one untill i cut it off with a hacksaw and made my own shortram intake. No idea if it made more HP but it looks and sounds good.
Old Jun 28, 2007 | 07:22 PM
SHT35T's Avatar
SHT35T
thanks everyone....so the velocity stack is actually in the filter housing and not the actual tube...air filter housing > maf > tube > tb
Old Jul 31, 2007 | 05:06 PM
CaliCal's Avatar
CaliCal
I just bought a 2006, 6spd...yahooooooooo! This car is baddassss!!!
Although I felt the engine was restricted, either the air filter or exhaust... but the stock muffler seems to sound/flow pretty good. So after reading the web, the word is to keep the stock airbox. It is actually designed pretty well, a radiused snorkel type inlet that smacks right into flat panel filter, then a pretty straight tube to manifold. Only thing I would add is an inlet extension to the grill. So I added the K&N panel filter ($40) and Shazaaaam!! What a difference... Immediate throttle response, no lag, quicker rev up, and carries through entire RPM range.... the stock box gets pressurized from RAM AIR, so I highlu doubt any CIA will flow better with all that turbulence and misdirected hot air from engine..... Hope that helps y'all....
Old Aug 1, 2007 | 07:50 AM
r3zon8's Avatar
r3zon8
strange, i looked inside my 06 z-tube and see nothing that even looks like a velocity stack. its just a straight tube from end to end.
Old Aug 1, 2007 | 09:41 AM
sry110's Avatar
sry110
Yeah I think the only velocity stack (sometimes also called a Venturi stack I think...?) is the contoured ring mounted in the airbox between the filter and the MAF sensor housing. The tube is just hollow I do believe.
apex locator
Jul 23, 2021 02:27 AM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
Sleeper_Z
Sep 30, 2015 10:25 AM
juang20
Intake
Sep 7, 2015 05:37 PM
