HKS hi power + kinetix HFC = SES light?
Hi, I installed the HKS some time ago... yesterday I put on the kinetix HFC (got them used here).. but after a while I got the SES light. Maybe they are quite old and not anymore effective but... SES light?
which check I should do now?
I ordered the fix for "test pipes".. so we'll see... but anyone here had same problem with HFC?
thanks
Matteo
thanks
Matteo
Originally Posted by joe645733
sound clip would be helpful
i made those on track....closed windows.
wait for better...
Matteo
Originally Posted by Ataru074
ok... I'm adding a couple more... but.. no clue about SES light? :-(
do you had that problem with yours?
Matteo
Matteo
and in ur inside vids, are u starting at like 4th gear @ 30mph or something?
or do u have an auto
seems like ur going through gears to slow
get one outside of ur car.
btw.. is 3th gear. manual.
I tried w/o the camera the none to 60 and looks fine... same for none to 100..
I'll go for a reflash soon... looks something is wrong.. maybe I'm too lean
Matteo
Originally Posted by davidv
Very unusual with high-flow cats. I would have a diagnostics done before installing non-foulers. The problem may be something other than bad cats.
looks slow also to me.... but 93% humidity and over 90 deg doesn't help a lot.. :-(
Matteo
Matteo
I've had the similar problem...had an used set of helix test pipes installed about 2 weeks ago, and today the SES light came on out of nowhere. the car just hit 33,300 miles when it happened?
I'm assuming your running high-flow cats since you said HFC's... you shouldn't be getting a light at all. I'm running UR HFC's with the Nismo and I've not had a problem yet. I'd check your hardware and all your install points. Something must be wrong.
I'm waiting to reflash.. maybe we'll see what's wrong on the dyno.
Matteo
got the same problem with my UR HFC and Topspeed Pro 1 exhaust ! After 70 kilometeters SES Light came on! Is there a problem with some exhausts maybe ?
I know that there are SES Light problems with th UR HFC and the Invidia g200 too !
... I kept "some sort" of cat just to avoid that problem... but later I'll go to autozone to try to understand if the o2 sensor was broken.at this point better to be afraid than sorry... If eventually I'm running too lean (HFC, hks true dual and plenum spacer on a 06) I'll keep the car at home until I can get a reflash.
Matteo.
btw. is ist possible to running lean only with HFC and 3" exhaust ?
the two on the cats are ok.
Matteo :-( :-( :-(
