topspeed pro
Old Sep 1, 2007 | 12:12 PM
carlos305's Avatar
carlos305
Default topspeed pro
i just bought a topspeed pro n1 exhaust and i was wondering if their is any welding required to remove the stock exhaust and install the new 1? Is it completely bolt-on? How is the difficulty level from 1-10 (10 being hardest)?
Old Sep 1, 2007 | 09:47 PM
Malikot's Avatar
Malikot
Rice Rocket
No welding needed. If your doing it yourself make sure you have some WD-40... the hardest part of this whole task is getting off the stock one. Once thats off its just a few simple bolt ons. Difficulty? If its your first real mod your doing yourself maybe a 5? It is VERY simple to do.
Old Sep 3, 2007 | 04:10 AM
wayneside's Avatar
wayneside
will be very easy...get a friend to help.
Old Sep 3, 2007 | 07:19 AM
singh's Avatar
singh
_______________
Don't take this system to a muffler shop, do it at home & save some money. Its very simple installation, and its only an axle back exhaust system, not cat-back.
Old Sep 3, 2007 | 09:04 AM
IIQuickSilverII's Avatar
IIQuickSilverII
yES INSTALL IS QUITE EASY.. jsut make sure you have the right tools and +100000 ont w40
Old Sep 6, 2007 | 10:37 AM
carlos305's Avatar
carlos305
will an exhaust void my warranty?
Old Sep 6, 2007 | 12:04 PM
Dui-Dan's Avatar
Dui-Dan
the only way the exhaust would void a warranty is if it can be PROVEN that the exhaust actually cause the damage ie: if you brakes go bad they CANT deny your warranty work because of an exhaust. install that bad boy and post a sound clip, im thinking about the n1 myself!
Old Sep 6, 2007 | 01:27 PM
IIQuickSilverII
no
+1 on what Dui-Dan(dui.. whats the story) said
Old Sep 6, 2007 | 06:30 PM
carlos305's Avatar
carlos305
i am planning on installing it this saturday is it a good idea to put on some wd40 the day before (friday)? btw i will try to post a sound clip as soon as its installed.
Old Sep 7, 2007 | 01:49 PM
carlos305's Avatar
carlos305
i got it installed but my silencer wont come off.... Any ideas on how to remove it? i already removed the two screws on each side and tried pulling it with pliers?
Old Sep 7, 2007 | 02:37 PM
wayneside's Avatar
wayneside
pliers will get them off...but you gotta grip hard!
Old Sep 7, 2007 | 03:11 PM
Dui-Dan's Avatar
Dui-Dan
vroooooom....
two for one night at chili's.... thats all i have to say about the dui
Old Sep 7, 2007 | 03:20 PM
ISMSOLUTIONS's Avatar
ISMSOLUTIONS
That all depends on what breaks and how nice your dealer is. It should not, and by certain laws - they cannot use that mod as an excuse for not repairing the car - unless there is a direct relation to the repair and it's use.
Rick
Old Sep 7, 2007 | 07:32 PM
carlos305's Avatar
carlos305
now im scared my car sounds like ****, i haven't been able to take off the silencer, will this make a difference? That silencer wont come off any ideas on how to remove it?
Old Sep 7, 2007 | 07:41 PM
rocks's Avatar
rocks
My dealer voided my warranty due to exhaust. Nissan sent me a letter, that it was voided due to aftermarket parts so yes they will void it if its a ******* dealer
Old Sep 7, 2007 | 07:49 PM
carlos305's Avatar
carlos305
well i work at nissan so i shouldn't have a problem but now i am worrried about da sound and the silencer it sounds like ****. The silencer wont come off..
Old Sep 8, 2007 | 06:06 AM
IIQuickSilverII
its unfortunate you did not post your story when it happened because you could have gone all over their *** for doing that...i dont even know what problems you had but i am 95% it wasnt most likely caused by your exhaust so they are in violation of the law.
read plz, and thank this democrats for this law cause it still saves tons of poeple with aftermarkets parts in their cars
http://en.wikipedia.org/wiki/Magnuson-Moss_Warranty_Act
Old Sep 8, 2007 | 12:20 PM
nator's z's Avatar
nator's z
I had the same problem with one of my silencers. I soaked the edge of the silencer with Liquid Wrench. Let it sit a good while then attempted to pull it out with vice grips. Little by little it started to move, soaked it again, kept pulling..........voila, out she came. Persistence should work. I did damage the silencer a bit (bent the edges in) but thats easily fixable.
Oh, I think I put a small screwdriver through the holes and gently wiggled it back and forth to try and loosen the silencer as well. Be careful with this step, don't wanna damage the muffler itself.
Old Sep 8, 2007 | 02:01 PM
Dui-Dan's Avatar
Dui-Dan
^mickey moused it huh?
Old Sep 8, 2007 | 03:12 PM
redkaz04's Avatar
redkaz04
ATTN: DO NOT FORGET exhaust sealant....put it all over your gaskets and the joints... the last thing you want on your first exhaust mod is a leaky exhaust that throws a code on your Z....
