piping size
Old Sep 7, 2007 | 03:53 AM
youcantzme's Avatar
youcantzme
Default piping size
hey i was just wondering what the best size of piping for single exhaust on a 350z, 2 and a half or three inch??
Old Sep 7, 2007 | 05:31 AM
Ruthless18x's Avatar
Ruthless18x
Depends what you want to do.
F/I - 3''
N/A - 2.5''
Old Sep 7, 2007 | 07:13 AM
Zridder19's Avatar
Zridder19
3" regardless, definatly for all motor I would go smaller than that. As far as F/I it depends on the setup you want to run, If you are going with twins I recommend a dual 3" And for a single turbo, I recommend a single 3"
Old Sep 7, 2007 | 01:10 PM
youcantzme's Avatar
youcantzme
are you sure?? i have 3 inch piping and im n/a... and i see no problem....
Old Sep 7, 2007 | 02:40 PM
TheJerk's Avatar
TheJerk
Can you tell us more?
On the HR teardown thread, they used a Greddy EvoTT dual exhaust with 2.75inch piping, and I heard no mention of Low end powerloss. I'm thinking the common belief that 2.5inchs is big enough is wrong.
Old Sep 8, 2007 | 07:01 PM
ISMSOLUTIONS's Avatar
ISMSOLUTIONS
A dual 2 1/2" and a single 3" should flow and perform the same, if the designs and components are similar is effect. The pipe size overall is equivalent.
If your going FI - turbo especially - you'd likely want 3" - though 2 1/2" will work - it all depends on boost and power goals.
Rick
Old Sep 9, 2007 | 09:27 AM
ct350z's Avatar
ct350z
I have lebree resonated test pipes which i believe are 2.5 to a custom 2.5 to 3 inch oulet y-pipe to a custom 3 inch b-pipe all the way back to a single hks canister.
Old Sep 9, 2007 | 02:35 PM
TheJerk's Avatar
TheJerk
Rick
I've seen 4cyls N/A run 3inch Pipes, and gain as much as 15whp, and lose nothing down low.
And Actually, as Shop here tested a dual 2.75 Inch pipes on a N/A Z and Made nice Numbers, and lost nothing down low.
Usually, the bigger the pipe, the better, I say Dual 2.5+ or go home.
sales@czp
Sep 23, 2019 03:30 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
